chungjun
- Nov 14, 2016
So after a day of owning these I definitely still really like the sound. However, I am having issues with the fit. I can get about 10 minutes before I start to get a bit of discomfort that turns into pain fairly quickly, especially as I try to adjust them and they push up against my ear in different spots. They fit very snug and seem to be held in place from multiple spots on my ear, but those spots eventually start to hurt from the pressure on them. Is there a way to alleviate this? Is it that I need to just keep trying different tips to find a better fit? Or are these maybe just not the best fit for my ears? Maybe try a cable without memory wire and see if that relieves some pressure too?
I now use Comply Isolation T400 (M) sized tip. For me, initially I had a 'tip-misfit' experience which was the source of the 'pressure'. Now with the T400 memory foam, the pressure sits right holding to both in place and its comfortable for me. Weight of IEM cable may also be something you want to consider? I switched to another cable which is slightly heavier and felt I could do with a lighter cable at times...
