Dark Helmet
- Feb 9, 2013
It's not the quantity it's the quality. Compared to my A83 it's not as dynamic. It sounds veiled in comparison. Ofcourse that is my opinion.
It's lacking the mid bass impact and speed I want. Seal is good.
Not crisp is comparison to the A83.The.. bass sounds... veiled? What does that even mean??
The bass is there, just not at quality I like. I did roll tips, and didn't have a problem with seal. I just wanted faster impact, more suddenness to the initial attack note of the bass and mid bass. Everything else about them seemed nice.Sorry, burn-in probably won't help. But I would try some tip rolling. It's both the good seal and the deep insertion which (massively) affect the bass on these IEMs. If you scroll back through the 1000+ posts on this thread (jk ), you'll see some who, like me, found more bass by working to get them set up right for their ears. Others were happy right out of the box. Still others couldn't find it, either because they never got the tip right, or because the large body of the IT03s seem to prevent them from getting proper fit/seal/insertion. Honestly, I never got any of the stock tips to get me the sound I was looking for, although I was able to find enough improvement with one set of the stock tips that I went off to find the perfect (for me) third party tips. It took Crystal Tips and Complys before I could really hear the sound/bass quality I expected from these.
BTW, unlike @SomeGuyDude, I'm not a 'burn-in' unbeliever. More of an agnostic. I typically listen to a new item for a few minutes to confirm there's no malfunction. Then I set them off in the corner to burn-in for a few days. After that I listen to what I've got, knowing the SQ may or may not have changed during the burn-in. I really don't really care one way or the other.
Seems like the only way to really confirm or disprove burn-in effects is to buy 2 of everything, burn one in, and then A/B compare the two. Hmmm two each of: Utopia, HEKv2, Ether Flow, HE-560, T1g2, IT03, Oppo Sonica DAC, Violectric v280, Cowon Plenue 2, Opus#2, along with all the associated cables. I really can't afford one of each of those, let alone 2. Good thing I got most of those items used
GLTY!
I think he's trying to convey the opposite of dynamic -- from thesaurus.com, that would be:
lethargic
lifeless
weak
boring
passive
dull
Perhaps you have found adjectives that work for you. I posted the ones that work for me.I'm saying that doesn't make any sense. Especially since there's quite a lot of it here. "Veiled" treble would refer to treble that's sanded off so it's less present. There's a "veil" over it covering details. That's not really something that can happen with the bass.
I really feel like at this point everyone just has a set of vague adjectives that mean nothing except convey an indistinct sense of like/dislike. "Well the vocals don't sound creamy enough" "yeah but the treble is so glittery."
You're the only one who complained. Boo.Protip: If your words aren't conveying an idea to other people, find new words. But okay. You do you, boo.
Here you go Pro.Protip: If your words aren't conveying an idea to other people, find new words. But okay. You do you, boo.
