jamato8
I have compared the cable to some expensive stuff and it holds up well. Not sure what you mean about electrical tape. I guess you didn't get the original cables. Also, once run in for a while, on mine at least, the bass is fast and solid. Maybe you got some counterfeit IT03, using the wrong tips or something but that doesn't describe what I hear and as far as holding up, mine have traveled with me to a number of places around the world and taken a lot of abuse. The tips will come off at times. I took a piece of sandpaper and took the shine off of the nozzle where the tip makes contact, problem solved for me.Truly a shock that a $259 pair of IEM's come with such bad tips that slip right off the nozzles, and such an extremely low quality cable (in physical & longevity terms). There's electrical tape holding the Y together and this cheap little piece above it that seems like it would break with any movement. Absolutely disappointing and frankly embarrassing. I've had $27 chi-fi come with better tips and cables.
Bass on the IT03's is fairly neutral, but it's not this "loud fast crisp" bass -- it's just...neutral and balanced, so I see why someone may think it's not really there. It was different than I had expected. Soundstage is less than impressive and narrow.
Fit is just ok but YMMV. Being a female I might have smaller ears or something. I can't find any tips that fit well over time and can endure me walking around.
Tips make a lot of difference. The sound signature holds up well against my JH 13pro freq phase customs. If the wrong tip fit, the sound won't be enjoyable, IMO.
