linglingjr
- Jul 26, 2011
Yeah the k701 sounds extremely bad if you are not driving it correctly, the same probably goes for the hd600. because you're running it right off a computer and iphone I think you would be best off with the dt770s if you can get the 32 ohm version. getting really nice high impedance headphones is pointless f you are just going to run it off an iphone or computer with no gear at all.
