justrest
I don't care about those scratches, it is beautiful anyway.
It is gorgeous. I just gave up in keeping it immaculate, it just takes a nice sheen like old jewelry. But the key thing is that it is quite finicky with source.
DAP, it is slightly warm with big bass so need a source that controls this.Finicky with source - with DAP or music files (DSD, FLAC, etc.)?
I have try matching my Hyla CE-5 with wm1a and zx300 in another shop yesterday. In this shop, I am planning to purchase zx300 but wanted to make sure I make the right decision. Well, the wm1a does not sounds veil unlike in the other shop while the zx300 is new for demo so not yet burn-in. After comparing for a while, I decide to purchase the Wm1a as the matching with Hyla seems good but yet to confirm until I try for a period. So end up buying wm1a instead of zx300 as I do not want to feel regret buying zx300 when I think wm1a should be a better dap. From Internet, i found that the output impedance of wm1a is 0.92 Ohm so it should be a good matching. Moreover, I have been wanting to try the balance of the Sony too.
My loaners arrived
You are testing it single or balanced?
I am using the same PWaudio No. 5 cable as well with my Hyla CE-5. Very nice cable!
I have just bought the xba-z5 to pair it with wm1a on balance using kimber cable. As both are new so not burn-in yet but I am curious about Z5 as many have sing praises about the z5.
I use CE-5 with Effect Audio Ares II plus(2.5mm) to have a short comparison with z5 using wm1a. On single ended for CE-5, the Z5 seems more warm than CE-5 so the bass is not as tight as CE-5. On balance for CE-5, I am using 4.4mm Effect Audio adapter. Both bass sounds almost the same yet CE-5 seems better control and tighter than z5. Z5 has more body in the mid than CE-5. String seems better on CE-5 as more clarity than z5 due to the warmer signature that it has. Both has good depth and width soundstage. I am impress with Z5.
As for mid which alphanumerix1 describe CE-5 as slightly thin and recess. For me I hear as good clarity and I may not understand about recess in the mid. So far, I like CE-5 and the bass is the best so far. Until Z5 and wm1a are burn-in, I will compare them again.
I had the XBA-Z5 too and agree that it is a really good IEM. It pairs very well with ZX2 and WM1A, especially balanced.
As for CE-5, I don't find mid anyway "thin" or "recess". We probably have differently sound preference, as I find the mid really smooth and seductive for the vocals that I listen to, pairing with Calyx M.
