Yes, I did install with VST plugin, though did not have the VST wrapper. Did I completely read over that part?
Also, I was slightly confused by this section :
"Once you have found the resonant peaks, it is possible to create a list that contains a reference frequencies (say 500hz and 1000hz) to compare to the resonant frequency at several different amplitudes. Here, take a look:
Here I am comparing 500 and 1000hz to different levels of 7500hz. Higher level numbers equal lower amplitudes (kind of counter intuitive, but whatever). By quickly switching back and forth between my reference frequencies and the resonant frequency I can quickly discover which amplitude is the correct one and create my equalization based on that."
Am I aiming to match the general volume of 500hz at 0db, with 7500hz at X db?
