Aug 28, 2011 at 5:57 PM Post #16 of 18
Spooky; I don't know what purpose the cotton ring serve, but probably some dampening? What I do know is that removing the metal pins that held it together fixed my rattle. It looked kind of cheap and badly done, so I removed them and sew the ends together instead. Worked like a charm for me.
Just want to say thanks for saying this; I did the same thing and it seemed to eliminate my rattle. I didn't take the driver all the way out -- I didn't want to mess with the silicone if I didn't have to. But I did thoroughly inspect the black foam piece for any hairs or other debris and cleaned out what little I could find. That, in combination with removing the staples that were in the cotton ring (and sewing it instead) seems to have done the trick.
I was going to send them into the manufacturer (they're still well under warranty), but I figure that I might as well just keep them now that they're working well. I don't really want to be without them for a long time!
One thing I do think is strange is that I do not notice any vibration/rattle whatsoever from the left ear cup, so I didn't alter it at all. The way I see it, if it ain't broke, don't fix it. If it starts rattling, I'll take it apart and do the same thing. Otherwise, why bother?
Jul 11, 2012 at 3:23 AM Post #17 of 18
Freakin' Awesome!! Indeed the problem were those two little metal pins. Man, it's like learning to hear equally balanced again... can't believe how much my mind was self-forced to pay more attention to the then only healthy driver... THANK YOU SO MUCH!!!
Now if I only could get a pair of those gel-style ear-pads...
Aug 8, 2012 at 6:44 AM Post #18 of 18
