Glmoneydawg
Btw aluminum wire is not up to code here in Canada ....also makes for truly crappy motor windings...you might want to talk to your village elders about this
Why do you feel the need to convince others? Some deep seated insecurity, no doubt...
to try and squash silly myths that cause uninformed individuals to waste money? To put snake-oil salesmen out of business?
there's a lot of product being sold thanks to over-blown proclamations on forums like this one from people who think they hear all sorts of amazing benefits from stuff like boutique cables and expensive dacs and the magical benefits of burn-in. There's nothing wrong with trying to get down to some truth and reality.
I also have the opportunity to further understand how the product of recorded music moved from performance of the musicians to recording to mastering to arriving in my home.
I see this as a particular problem. Audiophiles typically have such an oversimplified and idealised notion of this process that it bares almost no relation to what actually happens and then they base all kinds of other conclusions/assumptions/assertions on those incorrect notions. For example, in the editing phase we have almost unlimited control over every aspect of the recorded performance. Have a look at this for example:
And have a look at the videos on this page to get a fuller understanding of the range of manipulations available: https://www.celemony.com/en/melodyne/what-can-melodyne-do
How often is Melodyne or some similar tool used? Pretty much ubiquitously! (although not commonly on acoustic classical recordings and some jazz).
G
Deepfake manipulation. Leave the imperfections in!
[1] Deepfake manipulation.
[2] Leave the imperfections in!
1. "Deepfake" compared to what? Deepfake compared to a reality that never exists? There isn't a recorded performance, there's a lot of different individual recordings done at different times (and different places) which are edited, processed and mixed into "a performance". In other words, the "deepfake" is effectively the reality of a song/track, while the actual reality is just sequence of individual instrument and vocal recordings.
2. Which imperfections? The imperfections which match (or improve) artistic intentions or the imperfections which detract from them? Did you actually watch the posted and other videos? If you had, then you would have noticed that while we can eliminate imperfections, that's neither the limit of the tools available nor how they are typically used. The tools allow us to manipulate the imperfections, so we can completely correct all aspects of any imperfections, only correct some aspects of the imperfections (while leaving desired aspects of the imperfections unchanged), not change individual imperfections at all or even make the imperfections even more imperfect, entirely depending on artistic intentions!
Aren't you exhibiting exactly what I suggested: "Audiophiles typically have such an oversimplified and idealised notion of this process that it bares almost no relation to what actually happens and then they base all kinds of other conclusions/assumptions/assertions on those incorrect notions."? You're assuming that there is "a performance" of a song/track and also, that all the aspects of all imperfections are deliberate/intensional and artistically desirable. The latter is never the case, even with the world's greatest musicians, let alone with those whose "talent" is partially/largely/entirely their marketability rather than purely their musical ability!
G
