Guys, first of all, you can only convince novices with blind tests, maybe because they are inherently open-minded.
Member Electroestatico seems very well advanced in going thru much gear, and in doing so has formed his own opinions.
Personally, I feel that blind testing is the only method that used to discount golden ear types, because it is so narrow in scope.
There needs to be newer better testing in headfi type situations, with headphones, which I don't see we have.
This would greatly reduce variables such as room positioning and whole gear variables.
Most all blind testing does not involve headphones or headfi associated gear, except dacs.
I beleive we can narrow the variables greatly with headphones and with more comfortable, less ambiguous settings or variables which compromise the minset and introduce doubt.
Doubt is like an eraser to the mind.
It destroys the decision making process.
when I was a noob and I got my first e10k fiio dac I thought I had it all and the perfect sound signal, until I went to a headphone expo and pluged my phones to other sources and also was exposed to the signal of a quest amp dac or when I heard the focal utopia pluged into a chord dave, thats when I realize how silly my perfecty flat and linear analog fiio signal it was and how little I knew about this hobby. Oh well live and learn. Im sure many here will no longer believe this no sense of all amps and dacs sound the same or that cables are all the same as they mature in this hobby
Actually you sound like your in a place I been long ago, and you don't realize you cannot really argue subjective points in a forum/thread that needs actual data.
Regardless how many may agree with you in other forums.
I myself have my own experience and viewpoints but I am at a point that I do not actually see any conflict,
Because you have to apply the data properly.
Most data covers specific scenarios which may or may not be sufficient for whatever the person is investigating.
I owned and really liked that unit when I had it, and felt it can compete with many high end units.
Yet I also felt it had its own signature, being wide , airy and sweet.
The problem is that my impression was subjective to me, and could vary to another.
Anyways, I do have a "proposition/solution" for this thread.
Place two dacs in some type of "summing" where we do the "null" experiment like carver did..
Actually it could be easy.
Measure and adjust output volume.
Then place the positives of both dac outputs (of same side-channel) across a headphone driver.
You could easily wire a headphone cable for both channels to play the difference of two sources.
Any difference at all, if any, would be produce an audible signal.
Yet that result would also need to be explained.
I am guessing a tonality difference could be a filter difference.
That would be a suggestion for this thread instead of back and forth arguments..
