Davesrose
- Oct 20, 2006
OH yes, I wish you'd see, I'm more in yalls side here.
Now... A thing I truly wonder... Do power cables matter?
But you do say you hear an audible difference between a "cheap" USB cable vs "$150" one (so in this context, what is "cheap"?....and you are claiming that certain digital cables produce a "cleaner" sound). Audio sound is considered pretty low band compared to current multimedia standards. With AV, there is various hype about getting a cable rated for speeds that are HDMI 1.4 vs 2.0 vs 2.1.....which allow for now up to 8K resolutions, 60hz, deep color HDR, lossless audio for (as I remember) 32 lossless audio channels. The highest spec is pretty overkill for now or years to come....as movie sources are still made in 4K (usually 24fps), 10bit HDR, 7.1 core Dolby Atmos. Getting some of these higher "claimed" specked cables seem more important for long cable runs. A digital source can accept more noise in the chain, as it just needs the threshold for adequate on vs off pulse (vs analogue which would need larger bandwidth). For my audio journey, I have heard some differences with sources (what I chalk up to different EQ/DSP), but have yet to hear a difference in a given digital cable when plugged in the same devices. The only main limitations I have found with digital cables is HDMI: which when I did upgrade to OLED TV and Dolby Atmos receiver, did have some old HDMI cables that couldn't carry the wider color range with higher resolution (so it's an apparent issue with handshake between devices).
