Home-Made IEMs
- Thread starter Bilavideo
Do you mind sharing a link?From Ali express with a soundcard. I asked the seller if is original and told me yes.
Thank you so much, I'll get the first one as it fits my minidsp umik-1
Farquarl
- Jun 20, 2016
Yes the limit is not reached but the phase shift of 45° for a 1st order is. Take a look at this picture, it shows that the phase shift of 45° is achieved at the corner/frequency which has only -3dB.Now I understand what you mean. The phase shift is 0° for frequencies the filter lets pass completely and increases until the point where the filter lets nothing through. That limit is 90° for 1st order and 180° for 2nd order, but it's never reached in practise. I totally see why it makes sense to think about it the way you do.
Edit: That's what you meant isn't it? should have read it a second time this early in the morning.
stephensynanta16
Member of the Trade: 7th Acoustics
check for air leak on each hole on the nozzle bro, even just a little leak will drastically reduce the bass. masm7 is quite tricky to seal it airtight.Today i created MASM7 and... where is the bass?
Has anyone found bass in masm 7?
The sound is great, the stage is wide, everything is great. But bass is gone.
I have CIEM on GK-31732 and compared to MASM 7, they are just super bass.
Maybe I did something wrong? But I checked that all the drivers are working.
and yah, bro, GK is super bassy compared to masm7. Masm7 is more like a controlled bass boost. Masm7 has a weird yet very nice quirk where the it feels like the bassline is really separated from any the other sound. At first it might feels like it lack bass due to its quirk.
Get the seal airtight, Drive it on hi-gain.
The knowles one looks like its an adapter just for one balanced armature driver - i'm aiming to measure assemblies of multiple drivers.
What printer did you use? Do you have a 385nm printer?I tried with a resin from 3dresyns but didn't like the results, this latest test was with Dentona 3D Optiprint Guide 385. It's used to make dental surgical guides, figured I can't get safer than that! Bought it off amazon.
BigBublik
Bro, thanks for the advice.
I checked the 3D printed SLA printer and found leaks. Now I am waiting for the new ciem shells and will make them with tubes.
Tunzearplug
Hello,
I am installing Universal shell for you.Have a good print.
https://drive.google.com/file/d/1v5m1rAV36hylC2Qh2OteI6AwChQ6sCSq/view
Farquarl
- Jun 20, 2016
Nice! I'll post mine too as well. Keep those resources coming.Hello,
alanwcruz
- Jan 29, 2016
I use an inexpensive Elegoo Mars
Thanks. Do you use the stock UV Source of the printer? It’s 405nm like my anycubic photon. If so I too can print optiprint guide 385. What are your exposure Settings?I use an inexpensive Elegoo Mars
