alanwcruz
- Jan 29, 2016
Nice how did you scan it ?
Photogrammetry, the secret is giving contrasting color to the texture on your impressions. I used green and black chalk paint. Got great results.
You don't need the red damper with the Accupass loaded 38** drivers.
Depends on how you wire it and the cutoff frequency is depending on driver impedance.Thank you so much for the help.
One last question please.
I can't understand what uf does 4.7uf for example reduces the low frequencies and 470 uf for example reduces the high frequencies ? I want to cut completely the frequencies above 200hz to the 38D1X.
I must use 24ohm resistor and a 33uf capacitor and it will be 200.95 hz cut off " frequency low pass filter .this for the 38D1X
For the 2354 using a 220nf capacitor at 4 ohm dc will cut the bass frequencies from 180.86 hz and below.
