kmmm
- Jan 25, 2017
If you read it properly and see FR, it was normal tuning. He mentioned itself.
But still a hard experiment to play of.
What do you need from your sound.
BS6Z is more than enough, if you believe me.
MASM7 adds midrange, and prevent treble roll off to give it the airy sound. Bass is also prevented from bass roll off but midrange is attention here a slight more, so bass seems more flatter compared to @eunice BS6Z. I love BS6Z in itself.
Well, I was going to build the BS6+ zobel but then I had some extra RAB 32257 so I thought; what the heck - MASM7?
I really like the MASM3, but it could do with a touch more in the lower end.
I also made som Y-tubing I was quite pleased with (2+1Id) which will fit the BS6 nicely.
Does this seem right?
