Home-Made IEMs
Jun 20, 2019 at 1:27 PM Post #9,346 of 15,989
I want to thank everyone, because I learned a lot from you, and today I want to share, a measuring instrument that I created myself, an EMI meter, I hope to help everyone, just as you help me, I use the Smaart program and capito to sound with Pink Noise, with him I have a very good dedication, I want to thank #eunice for the tips that were through them that I could mount my meter, I still need the help of my friends, because I have a lot to learn from you
It feels like a Knowles standard measuring unit
Well done bro.....so now we got a homemade mic as per our calibrations..
Nice
Design is ready.
Finale 1
28mm tubing dampens the 6kHz of 7mm tubing. But due to long structure damping, the effect of damping decreases...so it is like slight damping filter, to the exact need.
The 56mm tubing targets the 3kHz peak. This makes the 3Hz more tame(long tube and smaller ID rolls off, which make the 3kHz strength lower than main tube, which controls the ability to cancel, so it act as a damper within it self.
Twin resonator is used for mixing phases, muffling peaks and creating a decay(natural echo artificially). Plus it helps in variable insertion depth in universal IEM, as it averages the peaks into smaller single broad peak.
Finally RAB-p famous horn structure
No dampers....
Parallel with zobel
RAB32063.
Why I am using closed BA. Because this much of tubing and structure if coupled with bass can lead to bass overhaul.
I want a straight line response with rising treble after 9kHz in BA.
I was late at posting, as I got blackening of gums due to heavy metal tartar build up(old medicine poison coming up....really old medicine when I was admitted).
Design is ready, did the simulation
Now its turn to make it real
Well I have patented it.
Can use for Homemade IEM, but please dont manufacture it.
It is for science purposes only and for understanding and education purposes
And I am a solo guy right now....so I can post anything for now...no company obligation
Jun 20, 2019 at 1:52 PM Post #9,347 of 15,989
Nice of you, thanks for sharing. Tell us how it sounds.
If anyone interested: I had that plopping sound again on the FED. Turns out it is the flux paste in the vent hole causing it! Just touched it with a toothpick so the hole is clear and the plopping sound went away.
Also a big heads-up to everyone using the ED-30761: It has a vent hole that is so small that it is not visible by eye. At least I can't see it without magnification. But it is there and must not be covered. (See datasheet for exact location). Doesn't help that the ED-30761 datasheet is hard to find, but soundlink has the relevant parts in the product description.
Jun 20, 2019 at 2:12 PM Post #9,348 of 15,989
Hahahaha. ... Hahahaga
Bad flux day
Bad flux...but its okay
It will sound something like Audeze headphones according to simulated graph.
Something like LCD2 classic
Dark velvety, grand life-like near vocals, and crazy stage
Image is compromised
Details are preserved
Total audiophile, not meant for mixing and mastering like Finale 2 and Finale 3
Finale 2 is neutral
Finale 3 takes best of both
But who knows, ears are better judge.
Jun 20, 2019 at 3:13 PM Post #9,349 of 15,989
Hi everyone, I am doing some tests and I would like the help of you, I am doing the joining of two drivers, the yellow one and a driver and the green and another driver, these measures were made separately
the frequency where it is circled in red is having the same frequency that they intersect, I am not reversing the polarity of the drivers
so when I put the two drivers together and do the measurement where it is circled in red is a very big hole, you can help me because this is happening, and how to solve it
Why is this happening? , the bass driver I'm using the low pass RC circuit and the other I'm not using anything
more independent of the low pass RC circuit happens the same way, and just taking frequency crossing or equalityat any point of two driver gets this hole
Jun 20, 2019 at 7:39 PM Post #9,352 of 15,989
how to solve this?
Short (non-helping) answer: adjust tubing, change RC filter or wire one of the drivers in reverse.
Long answer, not knowing your background I try to start from scratch. Imagine a sound wave as alternating high and low air pressure regions traveling through the inside of the tubes. If two drivers create the same frequency at the same volume and at the same time and both soundwaves travel through the same tubes (same length, diameter and so on) at the end of the tubes the soundwaves will be in phase. That means if you have high pressure region exiting one tube you will also have a high pressure region exiting the other tube. Both high pressure regions will add up.
The result is the sound of both drivers is twice as loud as one driver.
If a high pressure region arrives at the end of one tube while there is a low pressure region at the end of other tube at the same time, the two drivers cancel out. The result is the sound of both drivers together is silence, even though both drivers are playing.
On the electrical side you can flip the phase by reversing polarity (180 degree phase shift for every frequency), and phase is influenced by RC filters. RC filters have no phase shift for frequencies they let pass and approach 90degree shift towards the block band. Other things also influence phase like the inductance of the coil in the driver you are using.
On the acoustical side the phase is influenced by the length the signal travels (the phase shift depends on the frequency!) and other factors like resonators, dampers, horns and so on. There is tons of material to be found for speaker enclosures and very little about IEMs. But you get an idea.
Next the air pressure at the nozzle of the drivers influences the electrical impedance of the driver and therefore there is a feedback of the acoustical properties back into the electrical properties of the IEM
So how to solve?
Some use complex and expensive physics simulation software to calculate the phase ( @dhruvmeena96 for example) others use trial & error and again others try to build existing recipes from this thread to get a feeling for what can be done and what sounds good. That’s where I am at. I built 20 different CIEM and still don’t feel like trying my own designs.
Welcome at the entrance of a very very deep rabbit hole.
Jun 20, 2019 at 8:19 PM Post #9,353 of 15,989
I have a multimeter that can measure capacitance to 1% accuracy and those 10% tolerance 0805 4.7uF ceramic caps. They are cheap and easily range from 4.5uF to 4.9uF.
I measured a bunch of them and sorted them according to their real value. That way I know I have similar values for left/right and also access to 4.6uF caps.
Do you know if there's any type of capacitor that are more accurate and don't need this process of measuring it?
Jun 20, 2019 at 8:28 PM Post #9,354 of 15,989
To everyone who uses 2pin connectors, how do you cut your shells to fit the connector? I don't really like cutting it by hand with dremel, I think it is very imprecise.
@dhruvmeena96 do you have your designs organized somewhere? it is becoming very difficult to find it here in the thread, and knowing which one is more recent/better etc... If you don't, I think it would be awesome if we could make a document with specified design recipes that we like from here.
I'm still searching for a good universal shell to prototype that fits at least 2 large tubes and is easy to assemble and disassemble, to make some changes and listen, any tips
Jun 20, 2019 at 8:41 PM Post #9,355 of 15,989
Yes I have it in my copy
And you can find MASM on google image search. It, by mistake became one of the searched thing.
I will post everything on wikia soon though
Jun 21, 2019 at 4:21 AM Post #9,357 of 15,989
I am going to upload a better understandable and approachable schematic
Since my mouth is not paining me that much
And I am ditching dual RAB for triple RAB32063 for ease of use and better tuning capabilities and formulaes
Since I can control individual 2 point of frequency
