Dhruv is on fire lol. I haven't checked that thread for a few days and now I feel like I am back to school with those text book notes
I am half lost between all the designs that were posted.
It was first pioneered by ocharaku(tube phase cancelling)
Makoto yamagishi sensei
I read his paper, but it was all stated at cancelling single point and he didn't take the consideration of ripple effect of continuous cancelling and construction
But I inspected it closer and found out that it behaves something like newton ring and Thomas young double slit experiment.
Strongest point in center, then lower in quantity yet stronger reverse point, followed by energy loss to other point.
And then the effect of longer tube and difference of ID.
It gave me a tonne of variable(independent frequency variable and strongly dependent frequency, effect of decay etc)
And ocharaku use to tune the iem with specific tip. But if he would have added a resonator, all the dips and peak would have been smoothened out, so insertion depth variable would have been lowered and more smoother approach to sound would have been possible.
LOL
Have fun designing IEM(I just made it more complex)
Now the interesting part.
Recently I was reading the effect of ferrofluid and natural crossover.
Well it is related to natural crossover
And I was thinking of cheaper Savant
RAB32063 as ED29689
RAB32037 as ED30761
Now the catch is that 32063 peaks at 3kHz instead of 2kHz
RAB32037 peaks at 2.5kHz( ED29689 + 20ohms) instead of 3kHz
So how should I damp it, to get the same kind of response savant had
Plus I have inductance for both of the driver. Plus both are sealed driver, so they will be fast as heck
So that would be fun
Update(the above is valid, this is a new design)
RAB32066
RAB32063
Both driver share same 1.2mm tube stretched and the config end as resonator and horn like RAB-p
Damper is brown
Zobel circuit for Parallel full range
Rz = 28.5ohms
Cz = 6.5uF
