dhruvmeena96
So the bass does roll of, quite a bit in fact, but the roll of starts below 50Hz.
Knowles does hide that by showing the SPL from 100Hz up in their data sheets.
I was able to solve the distortion issues by adding another orange (!) damper to the ED, basically downgrading it to a bass only driver. That also shaped the signature a bit more to my liking.
Now Savant finale definitively sounds much better than the BS6, except the BS6 has slightly more slam below 50Hz. Listen to "Hands Up (Acid Mix)" by "Dense & Pika" if you want to know why I sometimes want that it's in medium quality on mixcloud in this set at 15:28: )
Thank you so much for this suggestion. Now the BS6 sounds quite colored compared to these...
I listened to the tracks and the mixcloud attachment.
Savant finale seems thinner or I would say leaner, but way fast in transient response and way to clear.
BS6 zobel is clear but I think slower and more fun to listen.
Savant finale seriously needs Benchmark DAC 3 to play to its maximum capability.
Savant Finale + CI sounds perfection
I think, better than Spiral ear SE5U
1mm ID tube on CI with three yellow dampers.
It just changes the way I see soundstage. It is like galaxy or I am tripping on psychedelics sort of feeling with CI and savant finale
Well I think we should change the names
Savant is copyright of noble audio
