Shilohsjustice
- Nov 28, 2014
What material are you using for internal stuff? I'm struggling with this right now. Fotoplast leaves that damn inhibition layer that runs, and the cyno I'm using leaves a film. After electronics are in, you can't do glycerin to cure.... Other than getting a nitro setup...
I use Fotoplast, I bought a "scorpion" flash light a couple years ago. It is a 395-410nm uv flashlight used for finding scorpions. It works well for spot curing areas in the shell where you need additional material around tubing and drivers. I haven't had issues with it running in the shell when I spot cute it.
I use this when I'm doing spot cures and for the faceplates. It works awesome, just like a professional wand.
Here is the light I purchased right from my Amazon history.
