tdx
- Mar 18, 2008
Hi everyone, getting a Spring 3 KTE this week, so excited! Does anyone have any HQPlayer presets for PCM and/or DSD to recommend? Thanks!
They are in description of this videoHi everyone, getting a Spring 3 KTE this week, so excited! Does anyone have any HQPlayer presets for PCM and/or DSD to recommend? Thanks!
Also try to make up your mind yourself.Thanks! Missed them somehow.
You can trial Euphony for 30 days, switching between Roonbridge, NAA, and Stylus endpoint for Roon outputAnyone aware of some free Roon RAAT endpoint bootimage?
Am using an HQ Player NAA endpoint bootimage on a headless Intel Atom mini PC and would like to try dual boot for some A-B listening...
Just curious, are you running Roon and HQPlayer on separate servers?Another rabbit hole...
https://community.roonlabs.com/t/option-to-replace-playback-engine-entirely-with-hqplayer/182473/22
anyone owning both Roon and HQPlayer with Qobuz are happily invited to do their own listening tests and tell me if they can also hear a difference.
But in all honesty it might be a matter of taste which signature sounds better.
For vocal focused tracks I might even give the Roon-HQPlayer combination thumps up for the less offensive presentation, for party mood the HQPlayer-direct solution.
As I am always inclined to get closest to the real thing I am now torn to either
a.) leave Roon, stay with HQPlayer setup and will miss the great comfort of Roon or
b.) go for some multi-purpose streamer supporting both worlds like IFI Zen Stream which is great for the money but technically a step down with max 3XX kHz compared to my current setup.
Thx, that's worth a trial.You can trial Euphony for 30 days, switching between Roonbridge, NAA, and Stylus endpoint for Roon output
That's really the only optimization I haven't done yet.Just curious, are you running Roon and HQPlayer on separate servers?
You can follow many rabbit holes but Spring 3 is sounding fabulous right out of my IPhone / IPad playing Bitperfect and I d be perfectly happy with that as a starting point.I plan on buying the spring 3kte as my next purchase. In the meantime I have been selling of some iem's because I want to put that money towards my headphone set up. One of the things I'm thinking of selling is my dx300 but I use it as my source and dac right now with my Soloist 3xp. I know usb is very highly regarded on the spring 3 so what would be a good suggestion for a source to replace the dx300 if I did sell it? Should I use my phone and a streamer instead. Any suggestions would be appreciated
I want whatever will give best sound quality. Honestly I'm sure my dx300 would do a great job too. I may just hold onto it until I figure out what option would work best for me. Thanks for the reply!You can follow many rabbit holes but Spring 3 is sounding fabulous right out of my IPhone / IPad playing Bitperfect and I d be perfectly happy with that as a starting point.
Haven't tried Android yet where I have made great experiences using UAPP in the past which brings dedicated exclusive DAC access plus Tidal / Quobuz...
Next affordable suggestion is Ifi Zen Stream (just arrived in my setup for testing), it's limited to 368khz PCM but if you can live with that it's sounding fabulous too out of the box plus having Tidal Connect, Spotify Connect, Roon support and HQPlayer support
These are plug and play solutions.
Afterwards you have a zoo of options like Raspberry PIs, Custom PCs, Mac Mini with player software or dedicated streamers starting at 500 bucks up to thousands of bucks.
Latter ones are not really needed with Spring imho
