Holo Audio Spring R2R DAC
Apr 13, 2018 at 5:38 PM Post #1,802 of 4,067
Gotcha. You should create a special little forum or blog on your website to discuss these things.
By cheap I tend to stay around $100 or less.
WireWorld Starlight 7 USB cable
WireWorld Equinox 7 balanced interconnects
Apollo HDMI cable
BlueJeans RCA interconnects
Eh…. For USB, I’d call $5 cheap, $12 a good target, and $25 extravagant, but whatever works for you. You can certainly spend a whole lot more than $100 if you want to.
Apr 13, 2018 at 5:52 PM Post #1,803 of 4,067
Yes, it’s all relative. There are cables that cost more than all the headphone equipment I have and a single cable costing $100 can cost more than all cables a single person might have by a large margin. Use whatever works for you.
Apr 13, 2018 at 6:05 PM Post #1,806 of 4,067
If your using a $12 cable on a $2500 DAC then good luck with that notion. I hope your able to try something that compliments the Holo Spring.
implying you need a more expensive cable to complement an expensive DAC? But you can also get a much cheaper and still well made USB cable that complies with USB spec.
That said, I don’t mind paying a bit more for aesthetics at times.
Apr 13, 2018 at 6:11 PM Post #1,807 of 4,067
So basically your logic is, not expensive enough, so therefore, not good enough. Not really a logic or have anything reasonable in the statement. Just something to move to the side as a silly thought.
Apr 13, 2018 at 6:16 PM Post #1,809 of 4,067
Let me ask everybody I spend more money on music server, cables and footers than the DAC. Am I crazy or stupid ?
Which my Aurender N100H is more expansive than DAC and my power cable and Intona, two usb cables and Isiacoustis Orea footers together more than DAC itself but now together all that my digital system can compete with much higher price point. For me everything is matter.
Apr 13, 2018 at 7:36 PM Post #1,811 of 4,067
I think you’re the perfect target for audio accessory manufacturers, that is all :).
Apr 14, 2018 at 11:16 AM Post #1,813 of 4,067
Gosh, I don’t even want to get started with cables. Especially usb cables. As I can’t post my thoughts on that to these forums anyhow. :) hahaha.
Many miss the very important facts about usb cables.
Nice Holo review in the May Stereophile!
Apr 14, 2018 at 7:10 PM Post #1,814 of 4,067
Thanks for the kind words! and also keeping this thread on track! :D
on another subject to those who are wondering if they have the XU208 module in their spring. check the Asio driver control panel.
under the info section there is a Revision number. if it is greater than v20.00
such as v20.16 or v21.12 are the two firmware for XU208 modules.
Apr 14, 2018 at 7:21 PM Post #1,815 of 4,067
Have the opportunity to try Exogal Comet Plus for a week. After couple hours of listening, it competes well with Holo Spring Level 3. I still think that Spring LVL 3 has a smoother top end, better holographic and more analog sounding. Will update the comparison in a week.
