gk2013
- Oct 26, 2015
Yes, you tried the RCA spdif output of the RED, I did not read carefully. Have you tried the RED in DDC mode? Do you still have this issue?
it is a lot to take inYes, you tried the RCA spdif output of the RED, I did not read carefully.
A few random thoughts:after testing here is a full sum-up of what i found so far:
sources:
PC
Jriver MC: Qobuz local file upnp/dlna / USB
Audirvana (trial): Qobuz Stream & local file upnp/dlna
iphone
Mconnect: Qobuz Stream upnp/dlna
next in line
Holo Audio RED
in: Ethernet or USB
out: AES/EBU - also tried Digital cinch-cinch cable (same result)
Problem
when playing the first track of the 50th anniversary album Dark Side of the Moon by Pink Floyd (from Qobuz) the DAC starts a series of clicks it would normally only make once at he start of a track when it is switching for the first time to a new sample rate. (as if the "handshake" is not landing, there is audio tho)
once the album is on its way it does not happen again (even on the first song). until i play a file of a different sample rate.
I have not tested switching from different sample rates to other songs on the album to see if it happens there too but I did hear it happen on other files while streaming random playlists from qobuz (which it does after it finishes and album unless you tell it not to in the settings).
- For now i am only aware of it happening on 24/192khz tracks.
- it happens on both direct streams PC - audirvana / iphone - Mconnect
and on the local file PC - Audirvana, Jriver
so it is not specific to "Source" PC/iphone or Stream vs Local File.
- it still happens when using USB in instead of Ethernet on the RED (Jriver)
- it still happened when changing the AES/EBU Cable to a digital spdif cinch-cinch cable.
- it Does NOT happen when i go USB direct into the yggdrasil.
When trying to use Audirva with USB to RED it started moaning about output levels and when ignored since it dont want to paly any levels it blue screened my computer. I did not change the vanillla settings !?! (are they wrong?)
I normally don't want level control on my digital signals unless i want it to automate leveling on mixed playlist using R128. (another strike for Audirvana)
so far my testing
i don't have other streamers - dacs (that support 192khz) - or AES/EBU cables to swap out
it seems unlikely to me it is a cable problem.
the ODD thing is it does not happen with direct USB into the Dac . but it does with USB into the RED. with both AES/EBU and spdif (cinch).
afaik the USBgen 5 board in my Yggy does not support Universal usb Audio but even if it did it would defeat the point of the red as reclocker.
anyone with ideas, or the possibility to test (if you have Qobuz) are welcome.
Regards,
time for some coffee
edit: forgot to mention that i have as of yet not seen this problem with the couple of 24/192khz albums i already had although i have not tested each track separately switching from a different sample rate (yet, ...maybe).
Thanks for your InputA few random thoughts:
I think I have only seen a Yggy click once when the sample rate changes, not multiple times.
Here's what Schiit says about clicking (at https://www.schiit.com/guides/dac-problems):
Clicking When Changing Sample Rates/Pausing/Etc.
1. It’s totally normal for Bifrost, Gungnir, and Yggdrasil DACs to click (mechanically, from the chassis) during normal operation. That’s the muting relay, doing its job. It clicks whenever the SPDIF datastream is interrupted.
2. If it’s clicking excessively on a Mac or PC, you can reduce it by routing system sounds to the speaker on a Mac, rather than to the Schiit USB Audio Device output. On a PC, you can set system sounds to "no sounds." In both cases, using USB largely eliminates it.
3. If it’s clicking excessively on a CD transport when in pause, the CD transport has a cycling interruption in the datastream. There’s no real fix for this, except getting another CD transport. It won’t hurt the Bifrost or Gungnir, though—the relays are rated for several million cycles.
Does the player software you're using allow you to set a resync delay? Roon, for instance allows this:
This sometimes works to fix issues like you're having. Here's what Roon says about it (at https://help.roonlabs.com/portal/en/kb/articles/audio-setup-basics#Fixed_Volume):
Resync delay
This setting is primarily used when an S/PDIF, AES, or I2S connection is involved. Oftentimes, a DAC will take a little bit of time to lock onto a new audio signal--sometimes as long as a few seconds.
This setting causes Roon to play a configurable duration of silence whenever it begins a new stream. Like the last setting, this one is a problem solver. If you find that the beginnings of songs are being cut off, or you're getting a lot of clicks and pops while your DAC locks on to an S/PDIF signal at the start of playback, try increasing this setting. 500ms is a good starting point. If that doesn't work, try gradually increasing it from there.
We default this to a very small value because it produces delays in Roon's user experience. Consider that when setting it up--unless you have an uncommonly slow DAC, settings longer than 1-2 seconds are probably not necessary.
One more thought - The Unison USB upgrade for the Yggy is awesome. In my opinion, it makes USB the best input on the DAC (which is strange, because when the Yggy first shipped, the USB input was arguably the worst). Schiit sells it for $150 (https://www.schiit.com/products/yggy-upgrades). You can have Schiit install it, but if you're even a little handy (and careful), you can do it yourself. I installed a few of them and it wasn't bad at all. There are GREAT step-by-step instructions here: https://www.superbestaudiofriends.o...l-gen-5-unison-usb-upgrade-instructions.4842/. Those are the instructions I followed, and it was really pretty easy. You just need to be careful and take your time.
Good luck!
who make comparision with Gustard U18 and Holo Red as a DDC?very effective for removing jitter, effect is like an optocoupler.
build a usbisolator.
cost 100 dollars.
from laptop to su6 or su2 or gustard u18 and holo red
https://www.mouser.dk/datasheet/2/609/eval_adum4165_4166_ug_2027-2934912.pdf
Goldensound Measurementswho make comparision with Gustard U18 and Holo Red as a DDC?
There is a good discussion on other site in the URD thread on how a cleaner looking spectrum might give better result in subjective listening then a singular Jitter number.
There's another option.so far i see that best desktop integration is with Roon or Audirvana but for hte moment i'm not looking for more subscriptions.
will check out Jplay ... oh noes more subscribtions
I already use Jriver for local files was merely looking for a way to stream qobuz from the pc since Jriver does not support Qobuz.. tho a better streamer than Mconnect would be nice also for portables.There's another option.
Run Minimserver or Plex Server for your local files. Both are free.
And run Lumin on your phone or tablet.
With Lumin you can both stream your local files, and stream Qobuz.
sorry i read over the 2nd part. yes i connected with usb instead of Ethernet andit still did itYes, you tried the RCA spdif output of the RED, I did not read carefully. Have you tried the RED in DDC mode? Do you still have this issue?
I have read most of this thread over the course of the last 4 months. I have forgot some that I have learned as it has been on and off, and sometime in the middle of the night... (terrible habit). Very helpful.
I received my red about a month ago. It is feeding my May into my Serene.
I am using USB out to MAY as I feel the May's treatment of USB can likely not be beat by any other connection method (and I am fan of I2S - as former Denafrips DDC/DAC guy). Enjoying the streamer thus far. Great sound - terrible manual.
A few quesitons as I can't seem to find...
What is Output device : Holo Audio UAC2.0 Gen 2 Enhanced? And should i be using it?
What is the USB redirector?
Thanks kindly.
I'm not using a Holo DAC but a Shiit Yggdrasil.Hello.
Output depends on which version of USB your May has. If it's the latest one, you should be using 2.1.
USB redirector, I have not found a use for in my setup so maybe someone else who has can follow up. It was discussed earlier here: https://www.head-fi.org/threads/holo-audio-red-streamer.965665/page-66#post-17583642
