Running HM901 on 2.004. Every time after new start it shows empty folders. Using 128gb card. After endless database update everything works flawless, until the next cold start. Any known cure?
I had a similar problem:
I used two 64 Gb cards working flawlessly for a year or so.
Then all of a sudden the same problem (like you had) with both cards.
I tried everything, and I mean everything(!) - all formats, all my files which worked fine previously. All firmwares, Whatever you can imagine in your wildest dream.
I guess I spent 20 hours or so of my time on this frustrating process.
Miraculously I managed to force to work only one of these cards - now in fat32 format only.
It does work after the cold start without forced rescan again.
Tomorrow I am buying one more card of different brand - to try my luck again and probably to spend 20 hours of my time on it again.
And I am buying Cowon PLENUE 1 128Gb, they say it has the stable firmware with very few glitches and bugs.
And having 128Gb on board I hopefully won't have to spend my time on cards but just listen to music...
