HM-801 Balanced Amplifier Module
Dec 24, 2011 at 2:53 PM Post #92 of 118
Please note that while it is very easy to replace the GanQi Bay standard card which comes with the HM-801 (as per pictures above, which could be clearer), you must be careful not to break the little plastic tabs (2) that hold the card down and in place inside the amp bay. The amp cards simply slot into the pin connector to the left chassis of the player; then the card is tucked down under the two plastic side supports just to keep it in place.
When you are first replacing the standard card with the Balanced Amp, the tendency is to press the plastic tabs inwards to disengage them from holding the current card: just a little too much pressure causes the cheapish tabs to break ! So be careful first timers !
Dec 24, 2011 at 4:01 PM Post #93 of 118
I seem to be getting a good 8 hours on 801+Balanced Amp+HE 300...
I get at most 5 hours with HE-500 and perhaps 6 hours with JH13
Dec 27, 2011 at 6:43 AM Post #94 of 118
Nishy, I am contemplating changing my HM-801 amp module over to the balanced one. I have had a look at this on Youtube:
http://www.youtube.com/watch?v=vUMzTAClfco&feature=related
and I am a bit confused as all it seems to show is steps 5 to 10 in the pictures above. What are steps 1 to 4 in the picture above as there is no text with the pictures above?
Thanks
PJW
Jan 8, 2012 at 10:05 PM Post #95 of 118
Hi, These pictures are a bit confusing! Just stick to that YouTube video as all you need to do is simply unscrew two screws off the cover, carefully depress the two side clips that hold the existing card in place, pop it out and simply replace it with the Balance Amp. Then close up. That's it. The Balanced Amp card is great! Best, Nishy.H
Jan 14, 2012 at 12:39 PM Post #96 of 118
Thanks for the advice - that worked fine. I have my RE-272s hooked up now. I will see how they perform....
Jan 18, 2012 at 12:53 AM Post #98 of 118
I would expect so, it powers HE-500 just fine both volume and dynamics/headroom
Jan 18, 2012 at 10:53 PM Post #100 of 118
Thanks Irvine, great to know, is it comparable to amps such as the lyr or the sr71b, or not even close?  Anything else you could about the lcd-2r2/hm-801 balanced combo?  I really appreciate it
Jan 19, 2012 at 2:05 AM Post #102 of 118
I would agree that it is equal to SR71-B but a different flavor
Jan 19, 2012 at 4:12 AM Post #103 of 118
I would also add that it is equal to StepDance with very close flavor.
Jan 19, 2012 at 7:48 AM Post #105 of 118
I think that what we are saying is that the HM-801 balanced module is about equal to both SR71-B and Stepdance in quality and that the Stepdance flavor is closer to HM-801 than the SR71-B flavour. I expect that SR71-B has the largest voltage swing so in theory should be the one best capable of driving very demanding loads
