warp08
- Feb 1, 2010
I was able to spend some time with Fang at the Charlotte, NC Can Fest on Saturday and was able to do some comparative testing of the HM-602 pre-production (read: minor changes should be expected in final production) model against two HM-801 prototypes, as shown in the pix. One HM-801 (mine) was equipped with the old ST opamp card and the second one was equipped with the latest (version 2) ST opamp card. I have tested it against the GAME card as well, but both ST cards had outperformed the GAME, so I have narrowed it down to those.
Headphones used: JH13 Pro/JH16 Pro/Sony R10
In short, my findings for the benefit of those who are considering pre-order:
Hopefully this will help out some of you who have been wondering about these issues.
- The HM-602 is a bargain for the money, especially at a preorder price.
- Overall SQ is nearly identical using 16/44 music to the HM-801, very impressive at the price
- Only after exhaustive listening sessions using 24/96 DVD-A extracted files (Checkfield - Surrounded) was I able to detect the edge of the HM-801s superior DAC configuration. If I had to enumerate the difference, I'd say the HM-602 can deliver about 80% of the HM-801s overall SQ. Fang has informed me that the difference is more evident once both models are amplified to speakers instead of headphones, but I had no way of confirming this independently.
- The HM-602's DAC will work with the iPad thru the photo connector kit (USB)...so does the HM-801
- I have asked Fang to find a source in China to obtain compatible batches of SDHC cards that will be tested with both HM-801 and HM-602 and provide as a way to obtain them at a reasonable cost. Some of us including me ran into issues with various cards and if he could pull this off, that would be great.
- Near-gapless playback will be offered, no full gapless feedback. That is not a firmware issue, rather it's a limitation of the main controller chip being used in both units.
- I have strongly suggested that a form fitting case preferably with some kind of belt-clip solution for the HM-602 be offered as an option, because the HM-602 is significantly lighter and more compact than its big brother and could easily be worn on the belt.
- The HM-602 will fit perfectly in the JHA carbon fiber optional otterbox, which is great for JH custom owners who ordered it.
