wormsdriver
I bought a two pack of these for like $15 on Woot.com a while back
Is the battery really that bad? H20 seems to find the battery half decent at least... 12 plus hours of playback. Still that is in 4 to 5 hour intervals and allowing the device to rest inbetween. The came concept applies to the Studio V.
The playback is decent but the problem is you always need to turn on auto shutdown after boot up and there are times I forget about it specially when your on the go
No I don't have that issue with having to constantly set auto shutdown... Strange. Once it actually activates auto shutdown it keeps that setting active on the next restart.
Maybe i just always forget to pause the track that i kept running because something i just removed the iem it self and it still plays on the background
Auto shutdown also works if you pause the music.
That's convenient. But is it really that hard to hold that same button for 2 seconds and turn the unit off? . I guess if you are unsure if you'll be back in 5 or so then its a good option regardless.
If I want to go to the kitchen and grab a sandwich or a drink, I would much prefer come back and resume the music where I just left off rather than shut the player down. Pausing the player allows this to be a reality. it's much easier than shutting down, rebooting, wait for the card to initialize then lose where I was at on an album. However, if I take to long making my sandwich or wonder of to stare out the window the player will shut down saving the battery.
How long does it take for this player to initialize a 32GB or 64GB MicroSD C10 card?and im just used to using ipod thats why i always try to compare both since i can get 30+ hours on it and not bother pausing or turning it off the whole day and i still cant get the exact charging time on this and i dont like over charging my electronics
The main reason BA draws so much power is because it needs to support an internal amp section seperate to put out 50mW, your ipod runs on a amp/chip so requires less power, and most cases sound quality is sacrificed. that's often overlooked when comparing battery times. The 32GB card takes about 3 - 4 seconds to intialize on boot up, unless you're switching out cards, which can take up to 60 seconds the first time.
