Erfan Elahi
Yess! And I am getting more as more hours passing. Now I am getting a fine sharp bass from the 1Z. I was listening to Manowar's Battle Hymns (2010's MMXI version). Wow the beginning bomb-basting drums, I felt myself standing with the drummer and I can image all the hits. Which wasn't a live feel at all with the ZX-300 or the with the Zeus before proper burn. Also the Led Zeppelin's 'Since I have been loving you' cover by Europe - the click on the base at the beginning is back again. I still don't have the flac of Paint It Black by the Rolling Stones, I can manage time to download tomorrow and check it.I sent my Ares ll 4-wire in to EA to be magically turned into an 8-wire and it's taking some time to get done and find its way back to me. So currently my Massdrop one is languishing in my music box minus a cable. But when I had the 4-wire on it, and compared it to the XR with the 8-wire, it was pretty close. I only had 50-60 hours on the XlV and the 4-wire to boot. When my new 8-wire returns, it will have a PSquared plug on it, so the two Zeus' will never be quite the same. Jack said the two would be identical, but I wonder as there are differences (shell and bore, particularly). However, so far the Massdrop didn't sound too far off. I do find that the more hours, the better the Zeus gets. My XR has at least 500 and it just sounds great.
The 8-wire gives more room for instrument and vocal placement (I find the soundstage quite wide even with the 4-wire). I don't think i"d want it any wider.
The thing about the Zeus is its transparency. That takes a little while to get used to. But once you do, and you realize just how much you can hear, it's pretty fantastic. It's not forgiving, though, and a bad mastering or mixing job is going to be really apparent. I'm not sure I'd go to a Hugo. You should investigate what kind of sound it brings to the party. My AK SP1000 SS is a detail monster with a fairly reference sound signature and it matches up really well. The copper version might give you a slight bit more warmth. What you don't want to do is find a source that removes the magic from the Zeus. You want to find one the compliments it. As to tips, FA suggests using the smallest possible ones that give a good seal. But if you move from silicone to foam you will pick up warmth and timbre for nominal cost.
Actually regarding Hugo 2, someone commented on the drop that it utilizes the full of the Zeus. Ya, I better go through some more reviews as my only priority is, if the Hugo 2 can do better than the 1Z only by sonics. Because unlike android devices, the Sony software performance isn't much processing power hungry and it preforms same as the $400 ZX-300a vs the $3200 WM1Z for loading database or playing native DSDs. But I will still get an upgrade find out if my ears can really hear difference from high tier cables.
What I was looking for was a detailed crisp signature. I can always adjust the EQ if I am in a bass mood. I finally got it on the Zeus. I started my first DAP as Sony and started cable setup with the 4.4 mm. Later, I have red about the fine clarity the A&K DAPs offers, but for battery and the UI of Sony I already adjusted myself. I am not thinking of a change any more.
To everyone, I know this is a dedicated high-end cable thread, my apologies for the diversion.
