Thailand : Mungkong Gadget, BKK Audio, Iconic Music, soundproofbros, Zoundaholic
Korea : Soundcat
Noted thanks a lot!
Korea : Soundcat
South KoreaI'm heading to Bangkok and Seoul soon for two weeks, does anyone have recommendations for shops that carry a wide variety of cables (and IEMs)? Looking to pick something up while I'm out there.
The PW Audio 1960 2 wire?After going from the Janus D to an Ares II it really puts into perspective the sheer size of the Janus, that cable is a monster. I'm actually really liking the 4 wire set up again. It makes my CIEMs feel like they're non-existent whereas the Janus would weigh them down a bit and did cause some slight discomfort.
Now I'm unsure if I should stick with my regular Ares II or upgrade to the 8 wire? I know the Janus D is thicker than other 8 wire cables due to the 24 AWG wire but it does have me second guessing.
Thoughts? Maybe another cable recommendation?
You forget about the cable after 30 seconds.
Yes, since it only 2 wires, once it on your ears, you won't notice it even thereThe PW Audio 1960 2 wire?
Who's to argue?Big bottom end on both, but the decay is slower on the 60(yr) and faster on the 80(yr)
BarraListening to the PWaudio 1950 4-wire now. Immediately I notice that there is a more balanced signature. The lift that the 1960 and 1980 have on the bottom end is removed with a more leveled response across the spectrum. The bottom end still hits hard, but at a more balanced level. I actually like the bass lift of the 1960/1980 better. Please note that the 18 has a significant low end that can blow your hair back so the pairing may be different on your CIEM. I also notice that the sparkle is similar to the 1980 on the top end for more details in your face. The 1950 has the euphonics of the 1960 and the sparkle of the 1980 with a more balanced signature. Again, this is a big WOW cable that stands out with a different signature mix.
Will have to spend more time with each of these on my other CIEMs to see if my opinion changes but so far, I am liking them in this order: 60 > 80 > 50. The 50 is the most expensive and most balanced, but with the 18, it is nice to see the bass unleashed with the 60 and 80. Between the 60 and the 80, the smoother 60 is an all-day listen while the sparkle on the 80 may get tiring as I am sensitive to treble. That said, there are a number of songs that I preferred the 80's treble sparkle to the smoother 60. In a perfect world, would own the 60 and the 80 for my a18 for variety plus the Venom.
So that is 3 down in the PWaudio tour kit, 9 more to go.
Wow, that is a tough one. Right now, my thoughts on favorite cables are the Han Sound Venom and Aurora and the PWAudio 1960 and 1980 and I have room for all of them in my collection for different reasons. They are all top notch and in the WOW class in cables. The Venom and 1960 edge out their brethren by a bit if I had to narrow down. However, the Venom and 1960 are different so it comes down to pairing and signature preference with equivalent levels of performance.Barra
1960 vs Venom which you like better and why?
