I'm looking forward to getting my ROOM's Audio walnut stand. I think it's better for my bedside setup than the Salire because I can easily hang the Susvara on it by its metal frame.
Yes, I only use the metal ones. They are great. The wood versions with fixed height are much lighter and feel less stable to me. And yeah, they may be too low.
Im currently driving my susvara's with a Cayin HA-6A, imo this combination sounds great for the most part but the HA-6A gets a little overwhelmed at times, really only when there is a lot going on musically and especially when there's a lot of bass in the mix. I've almost convinced myself i'd like to try something new... Ive read a lot of good things about and am leaning towards the Enleum Amp-23r. Just wondering if anyone has this setup and if so i'd be really interested to hear about your experience?
It will fit the Susvaras with the cables removed and hung on the band. The metal ones you can hang with cables, on the band or metal part of headband.
Here are some pics for reference. As you can see the metal adjustable setup is better suited for the Subarus. Epecilly because you hav room with cables attached if putting down while still listening.
I don't have an issue hanging them from the band when the pressure is spread across the whole thing, it's the narrow top of the Salire that concerns me on my Sus.
