IZONE
Over the years my thought process has evolved to something similar. I noticed that often I'm fooled by volume. It is often much easier to go louder using more powerful amps and listening much louder than when using regular headphone amps without noticing and indeed it will sound a lot better, things will 'open up' and details with jump out at you but it's just the volume. I think volume matching using an unbiased instrument is definitely important before running a comparison to say something can drive something well or not. I used to turn my speaker amp volume down to give it a clear 'disadvantage' and turn my headphone amps noticeably louder to make sure I wasn't fooling myself. What I noticed is that in 2021 headphone amps are a lot more powerful and headphones are a lot more efficient compared to 2011, even the Susvaras don't feel like the 1st generation HE-5 or HE-6s that really benefited from using an amp with 456 flux capacitors running in parallel biased to 1.21 gigawatts each with at least two dozen arc reactors from Stark Industries being used as power rails. Downside is that I could not use my Iron Man suit while listening to the HE-6 or travel back in timeI don't believe in using speaker amps for headphones...as the blown drivers on this thread speak to. Get a powerful headphone amplifier and you'll love these headphones! The HSA-1b, HPA4, GS-X mini, GS-X Mk2 and now the AMP-23R are all brilliant with these hard to drive headphones.
*I am still open minded though (I'm always open-minded) so I will definitely test some speaker amps whenever I can find the time from my corporate overlords. We are all living in the Matrix anyway so what is reality? Keep calm and enjoy the gear you have Neo...
