- Mar 29, 2002
I use the pass labs XA25 & Eddie current Studio with Excellant results
I use The Pass Xa25 with the susvara & no way does it run out of steam source is a emm labs transport feeding a Lampi Big7 Hegel p30 preampI found the Pass Labs was brilliant with most headphones, but did run out of steam with the Susvara. I preferred the GS-X Mk2 and GS-X mini FWIW.
I reached a point where I didn't want to unplug the Bakoon and switch to HPA4 anymore
Anyone tried one of the lower powered Pass amps like the XA30.8?
On paper power can translate to reaching sufficient dB SPL but it doesn't reliably tell the whole story w/ respect to sound quality.
It’s really an integrated speaker amp
It's a good point.
Stay updated on Forza AudioWorks at their sponsor profile on Head-Fi.
I had a go with FirstWatt F7 (technically it's a Pass) and it was okay(ish) with Susvara, but not up there with the best amps for these cans.
Really? Which Pass ran out of steam? A speaker amp or the HPA-1?
Definitely not the speaker amp...the HPA-1. But just with the Susvara and HE-6SE. Good, but not great with these 2 headphones...really good with everything else though that I tried.
Yes, I was around 0 -5, bass was lacking (compared to Susvara with an amp) but still there. the details, transparency, depth, was nearly as good as with an amp.
I’ve found that the more I’ve lowered the noise floor in my system, the less I’ve needed to turn up the volume which makes it munch easier to drive low sensitive headphones.
No, not at all. I’ve had DAVE turned up to -10 -12 on low volume tracks but never really more. For brief seconds I’ve turned it up even higher just to see how much juice the AFC-10 had and it never distorted.Gorgeous. Quick question, do you ever find you run out of gain on that set up? When I had the AIC10, I found that on some classical recordings, I would max out the volume. The amp is "only" 10W into 8 ohms but it really does sound like much more than that and has incredible synergy.
Bakoon AMP-13R is the best I've heard w/ Susvara. I ended up buying one after an extensive demo. If anyone is interested in buying one please feel free to PM me.
Harbeth P3ESRs
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Stay updated on Audio-Technica at their sponsor profile on Head-Fi.
I finally got mine too. A marvel of engineering. Amazing what they packed into that tiny footprint. Feels dense. Really minimalist controls. Susvara sounds great on them. Need to A/B with my other gear, but just off of memory I'd say they other descriptions are accurate. They sound great, but maybe only 5 to 10% than other great but lower priced gear. I paid a premium for the extra % points, small footprint and design, but I do like that I can use it as a speaker amp too.
I also took the unit to a dealer to audition them with some Harbeth P3ESRs. Sound amazing. Dealer didn't have anniversary edition so I had to scrounge the web to find a dealer who had the 40th anniversary P3ESRs. Can't wait to receive them.
Really great imaging.
Maybe....then why not publish them? Most manufacturers love to show them off.
