up late
- Feb 19, 2013
the susvara that i auditioned in-store had the 'catheter' cable
As someone who lives in an older condo building in the city, having a good power conditioner (which came with good power cables) made similar improvements to my listening experience. It was a good few auditions before purchasing, from the shop and also a friend’s house. I think it’s a good investment as it does benefit any new component and quite future proof. (I use Shunyata Hydra and shunyata cables in my main desk rig, and Plixir in my living room vinyl rig).Here's a bit of a different answer. After years of finetuning my system, here's where I've put my money (in descending order of value):
- amp
- power distributor and power cables
- dac
- clock
- headphones
- bnc clock cables.
- xlr interconnects.
- hdphns cable.
- tubes.
- ethernet cable.
I am fully aware that more expensive is not always better. This is just the current value distribution between my gear.
There was also some strategy involved. For example:
- My dac+clock sound superb, so I wanted a neutral xlr that just gets out of the way. Nothing too crazy.
- I want my music to sound as natural and analog as possible. Upgrading my power distributor, power cables and clock cables have relaxed the sound to a point where I can listen fatigue-free for hours. Probably the biggest surprise of my audio journey.
- Ethernet cables are a rabbit hole I've avoided, thanks to the friendly guys at dCS Audio. Apparently, the Lina dac solves most issues internally.
- I'm still sceptical about the additional benefit of high-end headphone cables in my already high-end system. I'll be receiving a dhc chimera with banana plugs next month. Not expecting my jaw to drop, but still very curious.
Next upgrade: Susvara 2.
Still using 4-pin stock catheter cable (less bothersome to me since I am in fact a physician so I feel right at home with it). Cp to Hart similar cable (Mogami copper used there though) I found this one better in terms of dynamics and air up top (slightly). I’ve been working on other aspects of my chain for Susv’s-the black cable ships with the newer batches - maybe 4-6 months ago.
no question I hear music differently at different times depending on mood or time of day...nighttime is for me much more pleasant I seem to be far more receptive...in addition some people have better hearing than other people, some are older etc..it is all very variable and I think one good reason why some people hear things others dont or even simply register themI think that burn-in and cable changes can 100% affect the sound. I heard a clear cable difference once, and it wasn't even close (OG Utopia stock cable was utterly garbage and made the upper midrange extremely forward, with a Forza cable voices took half a step back, not much, but enough to enjoy that headphone). That was the exception to the rule though.
The fact if you can hear that difference is something else. You can check out a few videos about comparisons and the physical science behind it, aswell as the psychological effect, it's rather fascinating.
In one of his videos he talks about looking at a picture that hides a lion in a rocky landscape. If you just look at the picture for 5 seconds, you won't notice the lion because he blends in so much. That does not change the fact that the lion is there. Once you saw that lion, you cannot unsee it anymore. Would you notice it ever in that first look? Most likely not.
Audio is extremely hard to judge, even if we humans have the very best thing that exists to do that - our ears. There are so many factors that play a role in listening, and while i think there are audible differences in cables, i also think that these differences are even a level below DAC swapping. Like: 90% headphone, 9% amp, 0.9% DAC, 0.09% cable, etc...
It will probably make more of a difference if you are tired or well rested, or if you have had a bad day or not. All these things can change the perception of sound.
For me personally: As long as i have good and nice cables (Forza Hybrid HPC, that price region), i (my brain) can most likely exclude any harmful effect. That's enough for me. Also i like nice ergonomics...
Freya+ is just at stage of contemplation. But thanks this encourages me to take the step - I just hope I can find good upgrade tubes eg the RCA VT-231 and Melz 1578 tubes seem to be unobtainium.Great setup there! I don’t really see any weakness in your chain. They’re well balanced indeed! Since you have the Freya, a speaker amp would be the best upgrade to go coming from the Burson
Thanks this is great. Freya provides lots of room to experiment and there are lots of experienced Head-fires to advise. It will be fun.BTW, you can also try switching the 6H8C and 5692 so that the input is 6H8C and the gain is 5692. It can also sound better that way more than the other
I wonder how will the heat dissipate when the chassis is closed without any gaps? Either the surface will get hot like a frying pan or the power gets castrated.https://shenzhenaudio.com/collections/gustard/products/gustard-h26-class-a-headphone-amplifier
As someone who loves the price-performance of the R26 DAC, I look forward to trying out this new toy for the Susvara.
Looks pretty high performance and potentially quite interesting. The only thing that jumped out at me in the specs was the atypically low impedance at the inputs. It won't be an issue for the vast majority of DACs and other sources (with output impedances less than ~600 ohms), but something to be mindful of.https://shenzhenaudio.com/collections/gustard/products/gustard-h26-class-a-headphone-amplifier
I did not notice that but you’re right, eagle eyes! Most modern dacs should be fine but yes, definitely something to be mindful of.Looks pretty high performance and potentially quite interesting. The only thing that jumped out at me in the specs was the atypically low impedance at the inputs. It won't be an issue for the vast majority of DACs and other sources (with output impedances less than ~600 ohms), but something to be mindful of.
