HiFiMan Susvara
Aug 4, 2022 at 9:45 AM Post #17,086 of 26,687
How about the Enleum 23r. Is it designed for headphones? I can see
TT2 is a great product. Sounds great and has adequate power.
Rear XLR does: 18W RMS 8Ω
Not sure about the Diablo but wary about portable amps. I used to own one of the portable IFI amps for the Arya V2 and at the time I thought it sounded good. Once I switched to the TT2 or AHB2 it was a night and day difference.
Adequate power from the SE headphone output?....aaand for Susvara?
or should i go with RMD DAC FS + Enleum 23R until I get a better dac?
Aug 4, 2022 at 9:54 AM Post #17,087 of 26,687
Aug 4, 2022 at 10:41 AM Post #17,088 of 26,687
Maybe do RME ADI-2 DACS FS and Benchmark AHB2? Unless you want to spend more on an AMP ...
Aug 4, 2022 at 10:44 AM Post #17,089 of 26,687
Aug 4, 2022 at 10:49 AM Post #17,090 of 26,687
But thats an poweramp?
Yes, I'm sorry. I assumed the RME can work as a preamp as well. I just checked the manual but didnt see any mention that you can use as a preamp? Do you have more info on this. I only owned this device for a week or so.
Aug 4, 2022 at 10:55 AM Post #17,092 of 26,687
You can use it as a preamp but he doesn't want a poweramp for the sus
Oh I see. I guess Enleum, used Bakoon, Ferrum stack or Nimbus would be top choices.
Aug 4, 2022 at 10:56 AM Post #17,093 of 26,687
I am not going to be extra careful and use power/speaker amps and stuff.
I need only an headphone amp for that matter :)
The Enleum is just alot of money just for the headphone. But some do swear that Rupert Neve Fidelice is the best they have heard. I am gonna think about this weekend. I don´t even have a balanced4.4 cable yet for the susvara :)
Aug 4, 2022 at 10:58 AM Post #17,094 of 26,687
Or a TT2?
Aug 4, 2022 at 10:59 AM Post #17,095 of 26,687
Or a TT2?
Does it really have enough power SE on the front(XLR/REAR not gonna happen). Im really into that one also :)....
Aug 4, 2022 at 11:21 AM Post #17,096 of 26,687
Rear XLR. Not the front SE. You just need to buy a simple adapter. Moon Audio sells some. No worries it will not fry your Susvara's. I would go TT2 and sell your other DAC. It's a better DAC/AMP anyways. Maybe get a used one under warranty. Warranty is transferable.
Aug 4, 2022 at 11:52 AM Post #17,097 of 26,687
Thanks but I dont think Im going for that. I would if I chose another headphone. Im not going to use them if the brand didnt design it for headphones. Never gonna happen…
I think I should buy 4.4 cable first, I see you have lavricables. Do you like them, which ones do you have for susvara?
Aug 4, 2022 at 12:01 PM Post #17,098 of 26,687
I like them. Use them on the SOLP but waiting for an adapter to try with the Susvara.
Aug 4, 2022 at 12:25 PM Post #17,099 of 26,687
I heard the Fidelice Precision which I tested specifically with my Susvara, and it’s just not good with it (details in my write of CanJam Chicago I shared in link further above)
Aug 4, 2022 at 12:30 PM Post #17,100 of 26,687
Thanks for sharing🙌
I think I should buy an adapter for Susvara xlr4 pin cable and just test the diablo.
  • Back
