Very nice! Yeah, I have had good support from Hifiman as well when my first Susvara failed.Got my replacement Susvara today, exactly two days after Hifiman received my defective unit. Now that’s service! I’m quite pleased with the rapid turnaround. Unpacked them, slapped on some Dekoni Nuggets, extended the yoke slider to maximum length, and connected my Cardas Clear headphone cable. Ready to go again!
It sounds just as good as I remember. Punchy yet smooth in my setup. So happy to have them back.
HiFiMan Susvara
acclimatise
That's awesome man. As expensive as the Accuphase is, it's an incredible amp. Also quite amazing for two-channel @orrm
Bear in mind its not overly warm. Just a hint of warmth in the lower mids and the treble is damn refined. It also has a big and powerful sound, be it with headphones or speakers. For the longest time, I drove the Sonus Faber Electa Amator III's off the e380 with great results, and with less gain than when driving the Susvara.
I have driven other speakers with the Accuphase. In general it pairs well with a wide variety of speakers I would say.
A CD player is a very simple solution. I don't want my system to be too complex, which can effectively control the cost.Nice, maybe I missed the post. So you are a hard core CD fan nice. I bet the luxman is more transparent and flat signature compared to the dense coloration of accuphase? The luxman pairing seems to be playing around Susvara's strength.
Of course, my system still has a long way to go. Esoteric needs an external clock to improve the sound quality. I am also interested in various advanced cables. Be patient
This might not be the right place to post, but what is your impression of Accuphase E380/TC-HE6-Susvara combo? Just researching an overall speaker amp for those TOTL cans.
I havent tried the HE6 off Accuphase. In general, I preferred Susvara with absolutely neutral and clinical amps like AHB2 which gets hyped, but even more so with energetic and dynamic amps like Naim SuperNait 3 and the lower priced Roksan K3 Power Amp. The Susvara was magnificent off Accuphase but still better off more clinical amps, whilst the TC was a revelation off Accuphase, due to synergy in tonality.This might not be the right place to post, but what is your impression of Accuphase E380/TC-HE6-Susvara combo? Just researching an overall speaker amp for those TOTL cans.
Thanks for that. So the hunt for overall speaker amp continue
thecrow
- Oct 18, 2014
Good response when (i assume) my hekse earcup connection broke too
Speaking of both potential accidents and zynsonix solutions...I have used my speaker amps without an adapter. As have plenty others including @GoldenOne.
Accuphase solid state to Hifiman planar drive should be fine without any impedance issues. I have checked with Accuphase as well.
The 170W output power is huge so you definitely want to be careful with the volume knob. If you unleash the full power, you will most certainly damage the Susvara, not to mention your ears. One of my friends fried his Susvara this way. He was using a headphone amp that he had maxed the volume on for a Susvara. Later he used it as a pre-amp to a power amp, but forgot he had the volume maxed.
As for good adapters, in terms of quality, try Brian Fox at zynsonix: zynsonix@gmail.com
https://www.zynsonix.com/
I had Bryan (@HiGHFLYiN9 ) build me a custom switchbox which I spec-ed. It is the the first one he shows on his website under the switchbox (that's my box; image below).
It has both XLR and RCA ins (to which I plug my Bricasti DAC), and can separately route each of them to any of 4 XLR and 4 RCA outs (which I use with various headphone amps, power amps, or active sub).
Now to the safety feature!
If you look at the image, you will see that each of the XLR and RCA selectors on the front panel has a covered switch next to it. That's because I spec-ed the 4th XLR out, and 4th RCA out, to require that the switch hidden below the red cover be turned on for the selection to go through.
That means that, in order to listen to the speaker amp (which I have connected to XLR out #4) to which I have connected to my Susvara, I am forced to di the following: change the XLR selector to #4, flip open the red switch cover next to the selector, and flip the switch below the cover to on. By this point, I am very conscious that I need to be careful and turn my preamp to low volume...
