Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
- Oct 18, 2009
I used some black nylons for dust cover. I've got pics up on the previous page.
Finished my Grill mod, and I also replaced the earpad dust cover with ultra sheer pantyhose. Not bad, eh? Jerg mods next!
Where is the grill from?
That is some good air to grill ratio. I think hifimanrookie had something similar
Indeed black does produce a wider soundstage and significantly increases sound quality.
Partially revised.
Christ I sucked at writing a guide back then.
While you're at it, i would recommend revising the pic of the pad sleeve you're cutting where the plastic ring goes into. I did as pictured and found it difficult to put the pad back on the ring because it kept slipping out! So it went from too tight to too loose. I would revise it to cut just barely past the holes in the ring.
