Even though I am in the RMAA and DBT camp some of these comments are extremely ignorant on how performance is measured.
I will keep it short:
RMAA is ONE metric not THE metric. That is all what JaZZ is saying.
@Bullseye:
Your logic is still flawed regardless of products for the same reason above. You are using one overriding METRIC as the overall determining factor for performance. Again I can reverse your own example and say the Honda Civic is much much better than the Ferrari, its easier to maintain, easier to find, more socially accepted, prone to get less tickets or stolen. If I change the metrics, I can change it up on you.
So again YOU got it all wrong.
Have either you (Bullseye and Cartharsis) actually listened to the HM or are you trolling? Answer this right now else its a complete waste of time arguing about it.
I was in your camp, borrowed the unit for 2 months, listened to it non-stop, compared it to other pieces of equipment, and you know what...it sounds orders of magnitude better than a Sansa Clip (thats apparent after the first 20 seconds of listening).
All audio equipment uses $10-20 components - same goes for computers (the PS/2 port was typically one of the most expensive parts to produce - but that CPU design is worth billions in development).
Listen to it first, THEN talk about it....
