lisnalee
- Feb 13, 2007
Just tried this with mine and it looks like that issue has been solved with the latest firmware version 0.11 2010-01-11. Can play a 24/96 file switch off and reboot and it continues playing from where it left off. The auto play on boot up has caught me out a few times as well, with my livewires plugged in and the volume accidentally sitting at ear busting levels. Now i always put the volume to the min setting before plugging them in.
The player still seems to have problems though playing the few 88/24 files i have, causing it to lock up and need reset much like you have described.
Originally Posted by Edwood /img/forum/go_quote.gif I found that the Player hard Locks up when playing 96/24 FLAC files, and then shutting down. It happens when playing a 96/24 file. Then shutting down. When powering up to resume, the player does not make any sound. If any other songs (including regular 48/16) are played, the player does a hard lock up, requiring a reset with the bottom reset switch. The SDHC Card then has to be removed before powering back up, otherwise it locks up again. And then you HAVE to play a regular 44/16 file BEFORE playing another 96/24 file. This bug makes listening to 96/24 incredibly annoying. You MUST play a regular 48/16 file BEFORE shutting the player off. I also really do NOT like how the player always resumes playback of the previous file even if it was paused before shutting down. The player should remember whether or not the file was paused. It can be dangerous because if you turn on with headphones plugged in, and have the volume up too high accidentally, very loud sound can suddenly blast through headphones. Firmware Version: 0.10 Date: 2009-12-24 -Ed |
