Oct 23, 2011 at 1:31 PM Post #467 of 480
I agree, the 801 is a waste with lower end phones too.  I never use it with anything lower than the esw9 which is borderline for the 801, usually with jh13 or Ed8 myself.
Nov 16, 2011 at 4:38 AM Post #469 of 480
32 GB is a limit for SDHC. The player is not compatible with the upcoming SDXC cards.
... until there's upgraded version of HM-801 ;-)
Just format it to fat32, it should work as long it is SD3.0 specification
Jan 11, 2013 at 5:01 AM Post #470 of 480
I had problem updating from 0.20 to .21 can anyone help?
running from win7 64bit
when i tried to open the internal flash memory, windows ask to format it, then I format to fat32, but windows fail to format, the messege ' fail formatting the drive'.
Thanks
Jan 12, 2013 at 5:34 PM Post #471 of 480
Thanks
Please don't format the internal drive! You might risk bricking the player.
To format a SD card bigger than 32GB, you need a software which will do it (Windows won't because 32GB is the official limit).
GUIformat (a free little program) did it for me. Put the 64GB or 128SD card in the slot on your PC or in a card reader and then use GUIformat to format it to FAT32.
Jan 13, 2013 at 10:07 AM Post #472 of 480
In the process to update firmware of HM801, I must copy the new firmware to internal flash memory of HM801, but everytime I tried to copy , the windows keep popping up ask to format it, cause I can't access it.
Not the SD card, unless someone know how to update the HM801 firmware from SD Card
Jan 14, 2013 at 7:31 AM Post #473 of 480
Does this happen when the SD card slot is empty?
I have installed new firmware on my HM-801 (and earlier HM-602) without being prompted to format the internal flash memory.
However, when I plug my HM-801 into the PC with a 64GB SD card (formatted to FAT#"), the Windows asks me to format the SD card.
This doesn't happen when the SD card i correctly formatted (max 32GB card w/ FAT32) or no SD card in the slot.
Try plugging the HM-801 in with no SD card in it and see what happens.
Jan 15, 2013 at 2:54 AM Post #474 of 480
I already tried that before, same result
Aug 29, 2013 at 3:30 PM Post #475 of 480
Hello friends, anyone have an older hm801 bios[size=x-small] below than v0.08 (0.03, 0.04, 0.05, 0.06) or links of them? please help me find it, i am fun of hm801 and im collect things that [/size]related to it, thanx for any info, sry for my bad english)
Oct 28, 2014 at 11:32 PM Post #476 of 480
Can someone send me or paste in a readable Playlist/Cue file that references music on the internal / external card?
I cant get the 601 to read any .m3u files, and I expect it wants .cue files, but I dont know how to convert them to what it likes :-/
Oct 29, 2014 at 3:38 PM Post #477 of 480
I would ask HiFiMan / Head-Direct that question if I was you.
From what I have gathered from another HM-801 user, only cue files created when ripping a CD has worked.
Oct 30, 2014 at 10:41 AM Post #479 of 480
  So theres
So, no such thing as a "Playlist"?
"Favorites" is the only "playlist" for any HiFiMan player unfortunately. Favorites won't let you order the tracks and you only have one "playlist" that way too.
When I had the 801, I moved some tracks to my "playlist" folders. When you use folder browsing, you can get a kind of playlists that way. Since I didn't change tags, I could still browse by tags and get all the correct tracks that way.
But no true playlist so far on any HiFiMan player - not even in the new series (901 and 802).
