Hi all,
I don't know if this is the correct thread for my question, but I didn't find anything explicit via search.
I just got my Hifiman (Firmware 0.19) and I have a question.
Is anybody able to navigate via Album, and if so how did you encode your music files, which program, which ID Tag Version (ID3v2.2 or ID3v2.3)?
I have ripped my music from CD via dbpoweramp as uncompressed wav and then converted to flac with ID3v2.3 Tags.
But using the Album entry it shows only this "No file!" message.
I can navigate the SD card folder structure using the SD Card entry though. I can also play tracks that way, but there is always an aprox. 2 sec pause between the tracks.
Doing the same with uncompressed wav files, there is not only a pause but additionally a loud cracking noise between the tracks.
Still, single tracks play very well.
I use a SanDisk 32GB Extreme (Class 10).
Thanx for any hints.
I'm also already in contact with support (thanx for help so far).
Well that have been a lot words
