Some impressions after burn-in, please take with a grain of salt, i haven't listened to a ton of equipment these are just my impressions and i'm by no means an audiophile
All sound impressions were eq'd using Oratory EQ Settings
Pads tested:
Dekoni Th900 Fenestrated - Improves bass and smoothes treble, more comfortable and fitting the OG Pads
Dekoni Sheepskins - Makes the sound more intense, everything gets amped up, but also a little tighter
Dan Clark Angled Ether Pads - For me this was the biggest change, felt like it drastically improved bass/detail/staging/depth...love the way these sound, these pads made a large experiential change for me
Amps:
Burson Soloist: After the Ether pad swap this was my preference amp to use, after the pad swap it sounds like the HP have access to more of everything basically.
Schitt Lyr2: Before pad swap this powered the HP really well, I probably listen too loud, so the volume was set around 3pm, great bass slam very enjoyable
LCD X Comparison:
My original impression before burn in and pad swap was that the LCD X was smoother, more sophisticated subtler depth cues. I believe this inital impression was accurate, but I think the He6se is more engaging and fun, it's the one I tend to always end back on. Now with the final pad swap, The the hifiman has more depth, more detail...but much drier, almost crisp, bordering on thin...this might sound negative but it's really enjoyable.
attatched the eq settings
