Hifiman HE6-SE
Feb 16, 2022 at 3:02 PM Post #2,821 of 3,903
Feb 16, 2022 at 3:16 PM Post #2,822 of 3,903
yessir single ended
regarding dekoni elite velour, i had used audeze. not sure if they are thicker with a steeper angle, that could also account for some diff.
but they had a similar effect to my lcdxc2021
Feb 16, 2022 at 3:25 PM Post #2,823 of 3,903
yessir single ended
Excellent.
Regarding "velour" - I can confirm that the stock HiFiMAN velour pads have nothing in common with the Dekoni pads. Arguably, the HiFiMAN pads, like HD6X0 pads, are proper velour, and the Dekoni pads are a fabric of some sort.
Feb 16, 2022 at 6:10 PM Post #2,824 of 3,903
I’m still loving the Audeze protein pads with heat shrink bass ports. No crinkling and better sound everywhere, no downsides at all to my ears. Dekoni fenestrated enroute just for comparison purposes.
Have some LCD4z on the way too so it’s almost time for another bake-off.
Feb 16, 2022 at 6:29 PM Post #2,825 of 3,903
just ordered some fenstrated as well, they seem to be a good option for ananda and he-6. if these arent it im sticking with velour. im spending more on pads than i used to spend on hp's...
Feb 20, 2022 at 4:50 PM Post #2,827 of 3,903
I am incredibly absorbed with the sound of HE6SE v2. I find them absolutely perfect, world class but with one con - they need a lot of power and I cann't used them mobile. Anyone can recommend me something similar sounding in IEM class ? Price up to ~ 1000 USD new/used.
Feb 20, 2022 at 5:06 PM Post #2,828 of 3,903
I've been perusing forums, looking for an open back compliment to my Verite Closed without breaking the bank and has timbre that would be as pleasing. Anyone consider this HE6SE (assuming with mods) to be a good fit here? Also, I have a Jot2. Would these be good enough to drive the HE6? Thanks!
Feb 20, 2022 at 5:12 PM Post #2,829 of 3,903
This is a great set of cans, timbre is very good. No mods needed.
Sound signature on my new pair is forward and bright but not sibilant. Really a fun and engaging headphone without any obvious sonic deficiencies. Cannot speak to your amp, I'm running out of a Master 19 (class A, 9 wpc @ 40 ohms) and loud/comfortable position is 40-50 out of 100. I need mo' powah :)
Feb 20, 2022 at 5:13 PM Post #2,830 of 3,903
I am officially putting my foot down on the "the Jot can drive an HE6SE" insanity.
It cannot. Anybody telling you that it can is lying.
The Jot 2 should have a great preamp out that'll allow you to run it into a nice old speaker amp that shouldn't cost much and you'll have a perfect setup. I am currently using the 100W speaker amp I paid $50 for until my Ragnarok comes back from repairs.
I usually run the speaker amp in the 12:00-3:00 range. 100W into 8 ohms.
Feb 20, 2022 at 5:22 PM Post #2,833 of 3,903
Hope your hearing is fine.
All things being equal, that's 16WPC into 50 ohms, not that big of a deal...
Maybe I screwed up the calculation, it's past my bedtime :D
Feb 20, 2022 at 5:30 PM Post #2,834 of 3,903
Thanks for the straightforward answer regarding the Jot2 here. I will factor in the need for another amp perhaps then... may need to push this out a little or sell my other equipment to make room. sigh..
Feb 20, 2022 at 5:43 PM Post #2,835 of 3,903
It really depends on a few things actually - the output of your source, whether balanced or single-ended, and what one considers "loud" or "loud enough". Specs for the Jot 2:
Balanced Headphone Output:
Maximum Power, 32 ohms: 6W RMS per channel
Maximum Power, 50 ohms: 4W RMS per channel
Single-Ended Headphone Output:
Maximum Power, 32 ohms: 2.0W RMS per channel
Maximum Power, 50 ohms: 1.2W RMS per channel
Not sure if that's measured using ~4Vrms for balanced and ~2Vrms for single-ended input from source.
Torq writes about power requirements here and suggests Jot 2 should be able to drive the HE6SE and do a good job at it, but he did not have one on hand to try it with.
Adding to this, Amir's measurements of Jot 2 vs. Singxer SA-1 shows 3.5W for Jot 2 vs. 3.6W SA-1. I have the SA-1 and it drives my HESEv2 to what I consider "loud" with lots of power left (lots on the volume knob).
