Hifiman HE6-SE
Feb 6, 2022 at 9:31 PM Post #2,701 of 3,903
I don't know what to say but the driver on the right side of my HE6SE from Adoroma just burned. When I put on the headphone a few min ago, I notice the righ side of the headphone is much warmer than the left side and it has static noise when nothing is being played. I started to play some music and I noticed something is wrong and I start the headphone test. In the beginning it seems the issue is just barely noticeable but quickly the righ side totally lost any sound except for static noise. I tried disconnect and let it cool down. Nohting change. I remove the grill and the pad to look for any stuck, it does not seems to stuck on both side.
When people are talking about Hifiman QC, I bought the Sundara and it has no problem for years and that's why I did not hesitate to buy the Adoroma's HE6SE V2 even there were some horrible stories reported here. Well, now it happens to me. I ordered on 1/3 this year and it just past 30 day's return window, how conveniently.
Feb 6, 2022 at 9:51 PM Post #2,702 of 3,903
Did you reverse the the cable connections to the headphones? I had a similar issue a few weeks ago, and it turned out that the supplied balanced cable was the issue for me.
Feb 6, 2022 at 9:55 PM Post #2,703 of 3,903
Thanks for the reminder, I checked the cable connections are fine. However, I might be wrong regarding the HE6SE since the problem might originally from my amp. I tried other headphones to test my tube preamp and amp, it seems that all headphones are having problems on righ side when I disconnect the preamp.
The Schiit Magni is the problem, schiit indeed happened!
Feb 6, 2022 at 11:57 PM Post #2,704 of 3,903
I checked ebay and did find any custom grills. Thanks for any links you guys might have.
Here's where I got mine: https://www.ebay.com.au/itm/265509140370?ViewItem=&item=265509140370
Ah, good to know! Than my comparison to your impressions I did earlier is moot since it was with old "Vegans" that are microsuede. I will add a note to that post mentioning that. Different material = different sound.
Sorry for not realizing this earlier, I've only ever heard people call the microsuede ones the "Audeze Vegans" so I just assumed, which is always a bad idea! :o2smile:
No I'm sorry for using an established name for the microsuede pads for my new style Protein pads. I just figured non-leather was the 'vegan' option not realising the old vegan pads were a different material! These are the pads:
Feb 7, 2022 at 12:48 AM Post #2,705 of 3,903
Feb 7, 2022 at 2:30 AM Post #2,706 of 3,903
Thanks, those look good. But:
Postage:
Doesn't post to Czech Republic | See details
Located in:
Loyalton, California, United States
We actually have a very big 3D printing community here. I'll check the local forums, I guess there should be some people who could help. Thanks.
Feb 7, 2022 at 3:47 PM Post #2,708 of 3,903
I was tempted by the price of Elegia, however, most of the reviews are not good and buying this to have a taste of the focal headphones seems to be not a good idea.
I had a very specific use case, closed back for acoustic music only. For that I think these are another real bargain from Adorama.
Feb 8, 2022 at 1:10 PM Post #2,709 of 3,903
I had a pair and thought they were great, could not understand the heat they took. Not fatiguing, not remotely harsh, quite pleasant sounding. Not the last word in detail and objectively not a basshead can, but I found it quite agreeable.
Feb 8, 2022 at 8:35 PM Post #2,710 of 3,903
Just received my 1/4" to 3.5mm adapter and I am able to test HE6SE if it was burned by the Schiit amp. It turns out my HE6SE is fine, I found that actually DX160 can drive it, not as loud as I like but pretty decent.
Will ship the Schiit Magni Heresy back for repair, the shipping itself could be 1/3 of the price of Magni (I just paid $35 to ship my UM Mest Mk2 back to MusicTeck, guess it will be similar for Magni).
In the meantime, my wait for Flux FA-10 is more than a month now even though I was told the lead time was 15 working days.
Feb 9, 2022 at 7:28 AM Post #2,711 of 3,903
Just got my "new" HE-6SE V2... which appear not new. All seals were broken, both the one on the shipping box in Chinese, and also on the inner Hifiman box. I asked specifically and the seller responded "these are a new, factory sealed headphone." I'm waiting for a response from the seller and if I don't get an appropriate adjustment I'll open a dispute. Can anybody say whether the inner pic is normal? I had thought the cable comes wrapped in a plastic bag. Thanks
Feb 9, 2022 at 7:50 AM Post #2,712 of 3,903
Broken seal is not factory new. Seen a lot of Hifimans in the last years. Broken seal before my eyes was either used or open-box.
Open-Box by Hifiman can be considered new as they are unused, just opened by customs etc.
Adorama? Not so much.
Feb 9, 2022 at 8:01 AM Post #2,713 of 3,903
Thanks. He packed the Adorama invoice with it, it doesn't show a price, but it does show the date and order number. So I just emailed Adorama asking whether they sold this as new or if it was a return, open box, etc.
Feb 9, 2022 at 8:11 AM Post #2,714 of 3,903
Where did you buy them?
Have you listened to it already?
Feb 9, 2022 at 8:19 AM Post #2,715 of 3,903
The guy is claiming everything is opened by customs. I don't think customs breaks seals on inner product boxes.
