How do amps like the ones from ampsandsound get away with only a 8ohm and a 300ohm output taps - their output trans are tiny too
OT on those amps were designed for high impedance loads.
My HE6se's have arrived. I did get the HE-Adapter with them. There was a note attached to the box that said "The HE6se must include the HE-Adapter". So I take that as it's up to the distributor to put them in box before shipping them out. Early impressions are these sound fantastic. Now my Hifiman collection is complete
It has the foundation of the HE6's but does everything better. The Susvara's is more extended on both ends of the frequency spectrum. But the treble has better clarity and is more detailed. There just seems to be more air around the notes. The bass hits just as hard but it's more layered and textured. The mids on the Susvara's just sound spot on.Is the Susvara close to either of those two in tonality?
Hmmm, I didn't get the extra pads.Both of my pair of HE-6 SE came with the adapter and an extra set of the cheap velour pads.
I only need 1 pair as I am going to get something else for my other system so let me know if any of you guys are in the market.
Discount time!!!
does anyone find the palipads on the HE6SE, make these sound way too aggressive? When i had a stock HE6 with the velour pads, i never felt that they were as aggressive as i feel they are now. I might have only put 14 hours on this pair, mind you.
Since you put 250hrs on yours, id wager a guess thats the difference youre hearing. Not the cables.
With respect to amp pairing, has anyone tried pairing the HE6SE with a HiFiMan EF6 amp?Its actually ok in terms of comfort. Its not the comfiest headphone I have owned or tried, but it is perfectly wearable and not the worst I have tried by any means. I'd recommend the HE6se with no problem, depending on what amp you have to pair with it.
It seems that the EF6 has enough power but not a lot seems to be written about the EF6 anymore and any opinions on the EF6/HE6SE combo would be appreciated.
Has anyone tried the Cavalli MCTH for compatibility with the original HE6 or the HE6 SE?
