omniweltall
- Nov 13, 2016
$276?? That's ridiculous.
This one below is the one. Pse check the ear opening if it fits. It has a round opening instead of ear-shaped one.
https://www.amazon.com/Dekoni-Audio-Memory-Replacement-Beyerdynamic/dp/B019QXEZHK
Otherwise, you can check ZMF Ori pads. It has ear-shaped opening that may fit better. Choose the lambskin version.
http://www.zmfheadphones.com/pads-and-cables/ori-pads
No need for fenestrated pads. Normal ones will do.
