I could easily live with a Susvara, LCD-5, or Caldera, but aside from those three, I've always heard something very characteristic about planar timbre that makes me choose dynamics over them.
While unpacking I was totally delighted to read on the outer packaging that the HEKv2S comes with a headphone stand!!
...later in the unpacking process I discovered that the "headphone stand" is a just super ugly piece of foam
Other than that it comes with 2 cables: 6.3mm and a RLX 4-Pin, both basic rubber cables but they are ok an easy to handle. I'll call them premium rubber cables.
Pls. share a comparison between V2 and V2 stealth version once you grabbed it. Obviously you are the only person with both headphones on hand at the moment. Did you bought it from Heiko here in Germany or local store in NRW?
Yes, I hope that will happen.
The V2 should actually be picked up today, but the interested party no longer reports.
So the chances are pretty good that I can make a direct comparison
Yeah all the HEK versions come with that wacky foam cover for the little nest for the cables! I’m assuming they still come stock with those bizarre bubblegum wrapped crimpy endlessly long and crazy bizarre noodle cables like my HEKse did?
I only know the HEK(v2) cables from pictures and the new ones are different as they are completely black and imo nice to handle. But I like braided cables better. The length is ok, I guess 2m Maybe? And the cables came into a separate litthe cardboard box
