RAZRr1275
- Nov 22, 2011
What do you guys think about a Concero or Bushmaster MKII dac for the HE-6 to go with my Bantam Gold as an upgrade for the ODAC?
I certainly understand your confusion. Answers are all over the road, and not having any experience with the HE-6s, I'm afraid I can't offer you anything more definitive.
Suffice to say that if you want 10 watts into 60 ohms, you need an amp that will push about 75 watts into 8 ohms. On the other hand, if the F5 will drive the HE-6 to sufficient levels, then all that's really needed is a few watts into 60 ohms in which case you're talking about an amp that'll do about 25 watts into 8 ohms.
And of course a given person's estimation of what's needed can depend a lot on what kind of music they listen to. If they're listening to music that's had a lot of compression applied during recording leaving little in terms of dynamic range, they would likely tend to be ok with less power. But those who listen to music with fairly high dynamic range, they may call for more power.
se
I listened to the f3 and j2. And they are not suitable for the he6. And we heard them both clip. And the presentation to me was bright and base light. Craig should chime in on this too. He ended up taking my krell home again to listen to it .
Al
Sounds like my decision is made. As for the plugging the HE6's to the amp, would I have to use the HE-adapter or is it safe to directly hook it up? I've read about people plugging theirs into 300+wpc amps without much trouble but I just want to make sure.
Also, from what I understand, I would need xlr to banana plugs to use with the wire that comes with the HE6's to hook up to speaker connectors. Any pointers on what cables are nice? I'm told that BTG audio stuff is nice along with them being able to replace the poorly designed connectors on the headphones with some better ones.
Thanks!
Yeah no issues here either, and the F5 is more than 2x the output of the F1J too. That makes you, potterma, dubstep girl, me and some others I can't think of that are satisfied. Something is fishy. Oh well, atleast you guys found something you are happy with.
Very nice vintage amp! Now what do you listen to?
@Steve Eddy
Yes, but one thing you don't realize, Steve, is that the F5 will push 8 Watts into 50 ohms. So will the F1/FlJ. First Watt amps are not rated the same way "common" amps are rated. The ratiometric approach is not correct. The F5 and F1 (and a few of the other First Watt amps) will put out 20 V peak ( >14 Vrms). They don't have the current capacity to do that into 8 ohms, but into higher impedance, like the HE-6, they will deliver.
@brunk
and others who care: the difference is the amp. F2, F3 and some others do not have the voltage output swing that the F5 and the F1/F1J do. Simple math, really. Its a lower voltage limit on some of the First Watt amps. They've the current ability, but not the voltage swing... With the First Watt amps, its about voltage swing, not rated power into 8 ohms!!!
