preproman
- Mar 16, 2011
BUT I DON'T WANT TO.............
How about after the new year?
Since the Hilo is out for repair and then on to Gary's review, now would be a good time to do this.
@hawkhead if your after a UK supplier of some Self Adhesive Stiffened Felt - check out this place: http://www.littlecraftybugs.co.uk/self-adhesive-stiffened-felt-black.html
Mine will be with me tomorrow
I have my received my Audeze Microsuede Pads and must say - it has done everything that ohhgourami and brunk has mentioned. It's improved my stock velour pads in bass quality, soundstage and I can feel the imaging from the centre which is big for me. Not going to remove the inner ring, just waiting to do my felt mod before sticking them down.
They are disassembled. Need to find the felt. I was looking at the wiring from the connector to the wafer. Pretty small solder opening to work with a large wire.What are you waiting for then? :wink_face:
I put the Hifiman Velour's back on this morning (just as a sanity check) and quickly put the Audeze vegan pads back on - they are also more comfortable for me
Are the pads vegan or leather?
I don't really like the Alpha Pads on the HE-6. They do wonder on the 5LE, though.
I think I'll leave out the ring, I don't want to risk any undesired vibrations, and the sleeve being stretched around the earcup keeps its shape pretty good. Hopefully my felt will arrive this week, it took a while for it to ship. I'll make a second set of "Jerg" grills too, taking out the cotton of course.
IMO, if the LCD-3 and HD-800 had a baby, this is it!Soundstage is between the two, bass is between the two, treble is between the two, but the mids of the HE-6 are still its own special brand. The HE-6 is now 'smoother' for lack of a better word, without losing its transparency and HE6-licious mids
I initially was going to use some flat copper cable, but decided it's a little too stiff for my liking, so now I'm going with a Canare Star Quad "permanent install" version type. It's a little larger gauge than the standard, and it has a 100% aluminum foil shield. Got it for $0.44 cents a foot too!
Let us know how you like the flexibility of the Canare... Looks interesting!
They look good , nice work. I am just amazed at the level people go to mod these headphones, I wonder if Hifi man put that much effort into research and development lol.
Al D
The foam isn't shown because it was taken off. Just peel slowly in case you want to put it back on.
And why isn't your driver gold?
