songmic
better amping helps improve, but i still feel this to some extent.
I could try using digital crossfeed with the Fidelia software (called FHX). I'll try it out and see if it helps.
+1
Am I the only one that feels this?
I haven't noticed it until recently, but I think one of HE-6's weak points is how it lacks a central focus compared to other TOTL headphones. While it has good imaging and transparency, if I close my eyes and listen to the HE-6, I feel that the center of the stage is somewhat vacant compared to left and right. Other headphones seem to do a fairly good job in emulating a clear center stage, but with the HE-6, something is missing. It may not be a big deal for some, but still...
Do any of you agree with this, or is it just me?
If this has been addressed as one of HE-6's traits before, is there any way to improve upon this?
This may or may not be HE-6 specific. To isolate this hunch with your system, auditioning the HE-6 with other front-ends and amplification could either dismiss or indict the HE-6.
angle the pads
I dont think the center image is lacking, it's just the typical planar headphone staging. That said, I am awaiting my Audeze MicroSuede pads to see if there's an improvement in this area. If so, then the HE-6 really pulls ahead of the rest. Can't wait to get my mits on 'em!
Put the audeze pads on last night. They are better than the hifiman velour which I thought lost something in the lower range. For placing the instruments I think the hifiman pleather may be a bit better than the audeze but still working it through. Also had a tube go so it messed up my comparison. The audeze are a pain to get on so not sure how much patience I will have either
Can anybody recommend a treble test song or album. Since the addition of the offramp my PWD has not shown the upper frequency harshness or peakiness I sometimes experience. I would like to sweat the HE6 through a treble grind. Similarly the T1, which performed better with the M7 than the PWD in my system, exhibiting some upper frequency edginess now and again.
You should try not using the hifiman disc.
