lambdastorm
- Sep 7, 2016
EQUAL TEMPERED ACOUSTICS.Do you have a link to his speaker company and this prototype?
I've had my original HE-6 + AHB2 combo for a while now. I've mucked around with a few other amps, but haven't found anything to dethrone it yet. I'm considering some other dacs though.
Are you running one AHB2 or two of them?
The HiFiMan HE6se loaner on tour came in and I have started to compare it to my early original HE6 and honestly it is not even close. The original is easily distinguishable as better. Also the HE6se needs even more power than the original to get to the same volume. I had almost ordered the SE but right now that isn't likely. I have a week with it so maybe things could change. I have no real mods on my HE6 other thant changing the mini coaxial connector changed to a pigtail Audeze connector and putting the Focus A pads on it.
I like the Dekoni pads as an alternative.I'm on my third pair of earpads with the HE-6. one pair of the included leathers and two pairs of focuspads. Any hints for durable and comfortable earpads for the HE-6?
edit: sorry if i bumped the wrong thread..
I agree with housing and other hardware affecting sound.
However i get tired of sh!t stirrers that don’t help people looking for info when considering a purchase.
And these things can get blown up in a few days and people spruik it as gospel.
I ain’t got time for that!!!
Seconding the recommendation for Hifiman velpads for my HE-6 (modded prototype with an HE-560 headband). The last owner (reddit) used the ATH-ADX5000 alcantara suede pads. Initially, they sounded great, but a third party storage box (made for the HE-560) that I kept the cans in was crushing the foam slowly but surely due to the clamp of the HE560 headband's spring steel. The mids started to dip and drift into the background. The previous owner supplied me with almost new Audeze vegan pads, and they sound great. However, I believe same thing would happen to them, hence I threw them on my HE-500's. FocusPads muted the sound profile of the HE-6 a bit, so they're a no-go. The stock velours were ill-fitting and rock hard, so nada. Enter the velpads. They are soft and provide great comfort. Moreover, with the HE-6 driven by a speaker amp, they brought the mids back and tempered some of the sharp treble reflections without losing much of the bottom end.I'm using Hifiman Velpads, and I really do find them to put out better response than the Focus pads. Focals pads do indeed output a more 'focus'ed sound, but it flattens the sound a bit in terms of imaging and dynamics in terms of warmth. I wouldn't have expected pads to have such a degree of effect on imaging. Velpads just seems most correct in terms of imaging from what I've tried so far.
These Velpads are really comfortable as they are pretty much like Sennheiser HD6-- series pads.
In comparison to HE-500, HE-6 does have better articulate mids, more dynamics, and sounds more holographic.
If you want to try ideal recording with HE-6, try this one. It has female vocals, cymbals, and horns. Which are sounds suited well with Hifiman planars. Also, it's just simply good quality jazz.
Yeah, they're physically different. Focuspads have perforated (p)leather lining the inner part of the pad whereas the velpad is just velour. Furthermore, the padding HFM used in the velpad is much softer out of the box (ootb) (feels like a broken-in HD6XX pad) than the irock-hard padding used in the stock velour (again, ootb). Alternatively, the Focuspad-A is velour except its outer side, so the inner part of the pad is velour. All of the pads listed above are angled pads. I never tried the Focuspad-A, so I cannot tell you how they sound on my HE-6. As for the build quality, the pads come already glued on to HFM's mounting rings, although just barely enough material wrapped around the mount ring for proper gluing.So are the velpads different than the focuspads? Got a link?
I'm in week 2 with my HE-6 that happened to be available as an open box from Hifiman. I just now changed out the stock leather (pleather?) pads to the included felt pads, and it does make a big difference in sound! It brings much more control to the sound signature. I see now why so many use the felt pads!
I've done a lot of mods on the he-500. But only cable and pad mods on he-6. I've read up on all of them. Of DIY mods I'd say fuzzor, pads, back screen and cable on that order@bagwell359 I know you've done lots of mods. Which are the best bang for the buck mods for the HE-6? I've been reading the fuzzor mod thread and it looks really interesting.
