Ok I have 2 speakers amp then.... just use any of them.
You will need a speaker tap cable for that to work,preferably with no resistors.
Thanks but first I have to find a HE-6 in good condition.
I read alot of positives regarding the Ragnarok and He-6.. The negative ones, where they tested with the XLR out or the Jack out? The jack plug in the Ragnarok is more like a convinience port. doesnt realy sound good compared to the XLR:Two threads to check that Rag/HE6 combo is here and amps that can drive the HE-6. From what I've read, it wasn't as good as a reasonably priced speaker amp.
Matt, no way to know until you try it personally
It's obvious. This site is a marketing tool to sell headphone gear. The HE has opened an option that no one considers with the push for the newest, shiny bobble. The hype engages many to participate by buying and having a say in the dialogue that sells.I think the most important bit to take away from the longstanding HE-6 amping debate is that most headphone amps are ridiculously overpriced and that it is very possible to find a speaker amp that secures equal or superior SYNERGY with the HE-6 for less cost than most headamps, while simultaneously the HE-6 is quite capable of scaling with higher-priced setups. The real question is why would one bother with a headamp at all unless one was tied down to a headamp already?
Speaking of small desks. Mine is kinda maxed out. Getting a seiviking stand for the He-6 but I'm not sure where to place it..
