jarnopp
- Nov 26, 2014
I cut the tabs partially off and then filed them down a little at a time until they fit perfectly.
Nice. I have a little wiggle room, so going to try the felt now.
I'm running them naked, any obstruction will affect the frequency response, usually adding to the 10kHz "tizz".
Thanks! How did you end up securing them?
If you remove just a little at a time from all four tabs you can make these "snap fit" where they are interference fit in the well where the original grill went, and fits perfectly in depth (as you likely know). If you do another set, try taking less off to start and fine tune the fit.
What's the preferred source for speaker taps to 4pin xlr cables? Just ordered a panache and eager to power he6 through the taps alone.
FYI, that second link is silver plated copper, yuck! IMO, go pure OCC copper, especially for HE-6.
How powerful is the amplifier for starters? I just got an HE-Adapter with my second HE6 that's going onto my Bryston for impedance matching sake and noise filtering, but you don't have to do this if the Amplifier is under 75w @ 8ohm, otherwise i would get it so the load from the amp doesn't blow your headphones or vise-versa (paraphrasing the owners manual.)
If you want just a straight connection from the amp, these are good to start otherwise you would have to look at more expensive custom options I'm thinking:
-Cheap One: http://www.ebay.com/itm/112266098555?rmvSB=true
-Braided, Longer, more expensive: http://www.ebay.com/itm/Balanced-XLR-to-SPEAKER-TAPS-PINS-HE4-HE5-HE6-HE5LE-HE500-cable-adapter-hifiman-/172391874411
-HE-Adapter: http://www.ebay.com/itm/HIFIMAN-HE-Adapter-for-HE-6-HE-5LE-HE-4-Low-Efficiency-Headphones-Amp-NEW-/162406758134?hash=item25d03276f6:g:TH8AAOSwWxNYry0r
I've been using a Q-Audio French Silk cable with my HE-6s. I think it is a very good pairing.
