I would consider the AHB2 to be nearly the pinnacle of what one can obtain for the HE-6. Before that, I'd say the Bryston 2B wins for that price bracket. Somewhere in between, the excellent Neurochrome HP-1. That's all just personal opinion though. There are a bazillion choices out there.
I've heard some of the older Burson stuff but wasn't really moved by them.
I am one of those users. As per my signature, I am using not one but two AHB2 power amps in bridged mono. These are the most transparent amps I've heard. Period. With anything I connected to them: speakers or headphones.
To give some context the last amp I had here was the extremely expensive MSB S201 power amp. The MSB is an outstanding amplifier and if I didn't hear the Benchmarks I would be considering buying the former. The MSB has a typical big class A sound - a certain liquidity and textured smoothness (my speakers at 96dB won't take this amp out of class A). That said the MSB doesn't match Benchmark's clarity, resolution or imaging and driver control precision. The grip these diminutive amps can have on speaker or headphone drivers is nothing short of amazing. But it's not a brutal sounding amplifier - soft music will play soft and delicate. Switch to something like Infected Muhsroom and you're in for the roller coaster. This is what I call true to recording resolution and transparency.
There are a few caveats with using the Benchmarks:
- In terms of resolution/distortion products, for a long long time my problem has been finding a suitably quiet/resolving amplifier to match my MSB DAC V (claimed to resolve ~146 DR). From an objective point of view with 133-135 DR (measured by 3rd parties too) the Benchmark is likely as good as it gets in amplification today. And with incredibly low distortion products. What I think this gives? Extremely transparent and precise to source sound. It opens a further window on true resolution, dynamics and clarity.
- It is only a power amp - adding a lower SNR / higher distortion preamp will put an unpassable veil in front of the Benchmark. Thus the bottleneck for most people I imagine is going to be elsewhere in the chain: source, preamp etc. Unless one has a matching upstream, you MAY not fully hear what the Benchmark(s) are capable of. But it will most likely max out what the source/preamp can give.
- The Benchmark even in dual mono, with max 380W into 8ohms is EXTREMELY quiet. I used these on low/medium gain with Focal Utopia and HD650 and no background noise. I don't know about more efficient headphones. I drives the HE-6s insanely well. In fact the driving ability with any transducers is incredible. Even the HD650 start having almost civilized bass control.
- The output impedance on speaker taps is virtually 0 ohms. This amp won't colour the sound - it's definitely not an amplifier that warms up / adds bloom / liquidity or any other fancy things to the sound. What it is, it's transparent and precise. It is not bright or warm sounding - to any level I could detect. It almost makes it hard to recommend to audiophiles. One better like the sound signature of their source and/or preamp.
- It's balanced ONLY.
